Tire vs. Nail: Mountain Pass Edition
Discussion in 'Wheels & Tires' started by SNO BUS, Feb 24, 2019.
  1. Feb 24, 2019 at 5:18 PM
    SNO BUS
    SNO BUS [OP] Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    Driving through Blewett Pass in Washington when my TPMS alerts me that the left rear tire is at 23 psi and quickly dropping. Pull over at a little espresso (Liberty Latte!! :thumbsup:) get out of the truck, and I can hear the tire hissing and losing air. Thankfully, it was a really nice day in Blewett; sunny and not snowing. Got out the tire changing kit. Literally the same exact kit that I got with my '91 Land Cruiser 28 years ago, still works perfectly. If you know how to use it, it's easy and quick. Much better than the scissor Jack and cheap tire iron you get with some cars. Temporary tire is solid, only a little bit smaller and not loud or anything. Thanks Toyota for making your customer's roadside lives easy!!!
    Now to address the next step of this problem: I would get new A/T tires, but these Bridgestones have at least 40k miles left on them and aren't terrible at all, plus the hole will be easy to get patched.
    TXMiamiFan likes this.
  2. Feb 24, 2019 at 5:39 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Is your spare 18"? I think everyone looks for a good excuse to buy something they want.
  3. Feb 24, 2019 at 5:45 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Tire Plug kit should be in everyone's toolbox. Could have removed nail, plugged, and re-inflated-providing air compressor on board too.
    Midnite72 and 15whtrd like this.
  4. Feb 24, 2019 at 5:50 PM
    SNO BUS
    Nick
    Washington
    Yup. 255/70/18.
    I know it's easy and quick, but when it comes to tires, I'd rather have a professional do it. Plus, like I said, even though it's a 3 ton truck, it was also quick and easy just to change the tire.
    Dag3 and ColoradoTJ like this.
  5. Feb 24, 2019 at 5:58 PM
    Only tires I plug are off-road tires on the trail that never hit pavement.
    A patch plug is the only way to go.
    TheBeast and 1engineer like this.
  6. Feb 24, 2019 at 6:11 PM
    Professional Hand Model
    Hand Protectors
    This^^^
  7. Feb 24, 2019 at 6:13 PM
    TheBeast The Beach
    now if you run bigger tires and a lift, that little jack is useless.
  8. Feb 24, 2019 at 6:15 PM
    Hand Protectors
    A nice fresh gooey thread of rubber plug with some rubber cement slathered on it has worked beautifully more than once. Its all in the prep and angle of attack. Needs proper trimming before driving. Plug and drive.
    15whtrd and ColoradoTJ[QUOTED] like this.
  9. Feb 24, 2019 at 6:16 PM
    4x4x6 block of wood. Good to go.
  10. Feb 24, 2019 at 6:19 PM
    I use them all the time, just not on the tires that may have went low and have thousands of pounds at 75 mph on them. Most time Discount tire has my tire ready in 30 minutes.
  11. Feb 25, 2019 at 8:07 PM
    SNO BUS
    Nick
    Washington
    Had Discount Tire patch it today, was pretty quick and they mounted it/put the spare back all free of charge.
  12. Feb 27, 2019 at 2:55 PM
    SNO BUS
    Nick
    Washington
    They plugged the hole up good and put some kind of rubber piece next to it, I guess to improve the integrity.
  13. Feb 27, 2019 at 5:17 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Isn’t that the plug they push through from the inside?
    pickeledpigsfeet likes this.
  14. Feb 27, 2019 at 7:47 PM
    SNO BUS
    Nick
    Washington
    There was no hole where the plug is, I'm not sure what it's there for. The hole was to the left of it and I'm not sure how they patched it.
  15. Feb 28, 2019 at 10:34 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    That's a plug patch, the nail probably went in at to much of an angle to properly install it, so they started at the hole on the inside and created a straight hole to insert the plug patch in. It is less than ideal to add a hole, but if you don't install the plug patch perpendicular to the tread, it could cause the patch to come loose and possibly leak.
