Tire Upgrade
Discussion in 'Wheels & Tires' started by ssfwb, Jun 3, 2022.
  1. Jun 3, 2022 at 9:05 AM
    ssfwb
    ssfwb [OP] New Member
    2018 Limited
    none
    I'm looking to put these on a 2018 Limited (no lift), it's a highway hauler for my camper (5500lb). The local dealer Specialist showed me the areas of concern. He thought there should be no issue.
    Original tires are Bridgestone...I hoping to go with the Michelin Defender LTX M/S 275/65R20, 34.1 diam. Have them on my '96 T-100 and they are great.
    Used a couple of spacers (1 3/16 deep), taped them to the 275R55 tires at the points that might give issues. Put the steering through full right & left, checking in small increments, saw no issues with the plastic flaps.
    Has anyone upgraded to this size tire?
    Do not want to do a whole bunch of 'mama jama' bs to make them work.
  2. Jun 3, 2022 at 9:46 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Welcome. Any particular reason for moving up in size?
  3. Jun 3, 2022 at 10:26 AM
    ssfwb
    2018 Limited
    none
    Nothing in particular. Thinking a little more ride comfort & mpg+ higher tire load capacity. My other alternative is 265/60R20, it has a higher load capacity than either of the others with only a small amount of tread loss and only 1.2" diam increase.
  4. Jun 3, 2022 at 12:57 PM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    You won't be gaining any MPG with bigger tires, not how that works, especially when towing. Rubbing on 34" might be minimal, sadly the only way to know for sure is by mounting them, you have to consider even someone with the same tire size can have different results than you, wheel offset, alignment and other components will affect where and how bad an oversized tire rubs.
    Oey12 and Txexplorer23 like this.
  5. Jun 3, 2022 at 1:04 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    a tire 34 tall and 11 to 11.5 wide will work on stock wheels (+60 offset) and stock truck. For reference a 285/70-18 tire fits stock truck with stock wheels. Move to wheels with less offset and you may need some work like bumper spacer, remove front air flaps and mud flaps. Larger tires for a Tundra are usually E load, so heavier. Expect to loose about 1.5-2mpg running E load 34s. Ride will be firmer too. And check out the many lift and wheel tire threads, there are a ton of pics and info of setups and mods.
  6. Jun 3, 2022 at 5:25 PM
    ssfwb
    2018 Limited
    none
    My alternate is
    275/60R20
    115T SL BSW
    800 A A 33" 11" 7.5-9.5" 8" 12/32" Standard Load 2679 lbs 44 psi 118 mph 42 lbs Black 630
  7. Jun 3, 2022 at 5:52 PM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Anything 33 and under wont be a problem at all, if your wheels have enough offset to accommodate wider tires (to clear the Upper Control Arm) then your second option will be just fine
  8. Jun 3, 2022 at 5:57 PM
    ssfwb
    2018 Limited
    none
    I just have an issue with all 'low' sidewall tires. (separate story) My '96 T100 had 31x10.5 15's, was kick ass.
    When it needed new shoes I put on the 'manual equivalent' Michelin 235/65R15. Super soft ride, great traction, but
    I am 5mph low at any speedo reading. WTF, I get it, should have gone with the original 31/10.5/15
    Am not impressed with the factory 275/55 Bridgestone Alexas ,29,000 mi and I'm looking at replacement...seriously Toyota!!
    I don't see the 275/60R20 having any clearance issues. My test rig allowed almost 34.5'' overall diam with no issues
  9. Jun 3, 2022 at 9:56 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    You won't get ride comfort... you will get a higher load rating and better control when loaded or towing.
    Michelins tend to be good for mpg, and my stock Bridgestones sucked in that department, but the high load rating is a negative for mpg.
  10. Jun 4, 2022 at 6:34 AM
    ssfwb
    2018 Limited
    none
    Thanks for your input, very helpful.
