Tire Temp Vs Pressure!
Discussion in 'Wheels & Tires' started by BlackRiverGuy, Jan 12, 2019.
  1. Jan 12, 2019 at 10:22 AM
    BlackRiverGuy
    BlackRiverGuy [OP] New Member
    Chandler AZ
    2019 Tundra SR5 4x4 Offroad
    In Process ARE color matched Z type cap. Pro Comp 3/1 leveling kit. Nitto Grappler 295 70 R18's
    Any tire experts in this forum?
    Question: Related to airing up after aired down. So after a weekend expedition, driving back on a primitive road to a decent highway, one would stop to air the tires back up, this means after driving a stretch of time the tires are now heated up. When looking at the tire placard on the driver side door jamb the tire pressures are listed for cold tires. Is there some kind of chart or data that lists what the equivalent pressure would be based on temperature? Or am I just grasping at straws?
    ColoradoTJ and Notachickmagnet like this.
  2. Jan 12, 2019 at 11:10 AM
    15whtrd
    15whtrd Mr. Blonde
    https://m.tirerack.com/tires/tiretech/techpage.jsp?techid=147
    Looks like a pain in the ass to me. Whenever I air back up after off roading I just add a couple psi. It will be fine. Just recheck them the next time it’s cooled off. The explanation on tire rack sounds like there are a lot of variables. It doesn’t need to be that complicated.
  3. Jan 12, 2019 at 12:48 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I agree. The difference in hot/cold PSI is probably not enough to prematurely wear the tires on your 1 trip back home. Just check them after the next time you let it sit for awhile.
  4. Jan 12, 2019 at 1:08 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Not hot enough to make much difference. Road racing tires can see as much as 10psi difference, but they are hot enough to boil water thats poured on them.
    15whtrd likes this.
  5. Jan 12, 2019 at 1:26 PM
    BlackRiverGuy
    Chandler AZ
    Thanks for the feedback! I did some further research as well, and yes there are many variables associated with this, almost enough to give one a headache, so as recommended in the above posts I will just inflate close to the listed psi, once returned home let the truck sit awhile and check again. Thats the game plan. Thanks again!
    Boerseun, HappyGilmore and 15whtrd like this.
  6. Jan 14, 2019 at 5:58 AM
    Stig
    Stig New Member
    You're making this way too complicated.
    Set the on pavement cold pressure correctly. Drive on the pavement for 20 minutes. Get out and measure the pressure. That's the pressure you can air up to if the tires are already up to temp. It's probably only 3 or 4 psi.
    Stormtrooper81 likes this.
  7. Jan 14, 2019 at 7:07 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    Any one look into running nitrogen in tires, had the tires on my last truck serviced with nitrogen and never had any issues with pressure changes
  8. Jan 14, 2019 at 7:13 AM
    Jengel451
    The Bitterroot, MT
    Nitrogen is a sales gimick. I used it when racing since the pressure differential is less due to no moisture etc. I honestly see no need for day to day use. The fact they charge what they do is proof they fleecing you. I read an article a while back that had a good analogy. "it's like rubbing cheetah blood on your engine to get more power"
    Sas, ColoradoTJ and Stormtrooper81 like this.
  9. Jan 14, 2019 at 7:15 AM
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    Normally a car or truck heats up at most 5psi. Many variables in the calculation. Niitrogen is not needed in passenger cars or trucks. IMHO
  10. Jan 14, 2019 at 7:17 AM
    Jengel451
    The Bitterroot, MT
    and to add, when we bought my wife's rig, I told them to get the nitrogen out and put regular air in, and to take that off the sales price. ;) And I wanted black valve stem caps back on. I hate sales people.
  11. Jan 14, 2019 at 7:22 AM
    Good topic.
    I just air back up to 3/4 of the max tire pressure unless towing, check later. Like others have said, maybe 5 psi.
  12. Jan 14, 2019 at 7:24 AM
    That’s some funny stuff right there.
    Did you tell them only 78% N2 or the deal was off? Lol. That would have blown their minds.
  13. Jan 14, 2019 at 7:33 AM
    don3032
    don3032 New Member
    don
    Just going off what I have experienced, we serviced all aircraft tires with nitrogen, and in my truck the psi will change about 5 after few minutes of driving, just enough to keep the annoying light sensor off. And it was free at the shop I went too, wouldnt have paid for it.
  14. Jan 14, 2019 at 9:16 AM
    HappyGilmore
    Trent
    Lakewood CA
    FYI if anyone wants to experiment, Costco fills all their tires with nitrogen and i think the self serve tire inflation station is nitrogen as well.
  15. Jan 14, 2019 at 9:19 AM
    Jengel451
    The Bitterroot, MT
    You'll need to purge all of the summer "normal" air out before you put any nitrogen in. that means EVERYTHING. Any moisture from normal air will negate any benefits.
  16. Jan 14, 2019 at 9:21 AM
    Stormtrooper81
    Lost coast
    2011 DC
    ColoradoTJ and Jengel451[QUOTED] like this.
