Tire skip
Discussion in 'Wheels & Tires' started by ian, Nov 22, 2014.
  1. Nov 22, 2014 at 12:29 PM
    ian
    ian [OP] New Member
    Ian
    When in 2wd my rear tires skip twice from a dead stop while turning.it only has 500 miles. Any clues.
  2. Nov 22, 2014 at 12:32 PM
    On dry surface? Traction off/on?
  3. Nov 22, 2014 at 2:42 PM
    ian
    ian [OP] New Member
    Ian
    Dry pavement traction off.
  4. Nov 22, 2014 at 4:06 PM
    What happens with traction on? Maybe the rear end binding like a 4WD vehicle would do while engaged in 4W and on dry pavement.
  5. Nov 22, 2014 at 4:37 PM
    andrew
    andrew where's the beer?
    andrew
    2012 rockwarrior
    stock
    How sharp of a turn, and how hard are you hitting the gas?
  6. Nov 22, 2014 at 7:45 PM
    ian
    ian [OP] New Member
    Ian
    Right hand l turn at stop sign and normal gas pedal pressure light if anything. Have not had it in 4wd yet since roads are dry
  7. Nov 22, 2014 at 7:48 PM
    ian
    ian [OP] New Member
    Ian
    It is always two skips.
  8. Nov 22, 2014 at 9:42 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Better take it in to get looked at... It's binding somehow and possibly the electronic limited slip system is malfunctioning, could be an ecu problem. If it's under warranty, no more questions, just take it in and let us know what the problem was!
    ODSteve likes this.
  9. Nov 23, 2014 at 8:33 AM
    ian
    ian [OP] New Member
    Ian
    Thanxs for the input
