Tire size
Discussion in 'Wheels & Tires' started by Rooskie, Sep 18, 2020.
  1. Sep 18, 2020 at 3:54 PM
    Rooskie
    Rooskie [OP] New Member
    Chad
    2019 Tundra SR5
    Hello,
    I drive a 2019 Tundra SR5 Double cab 2WD and I'm looking for advice and possibly photos on what size BFG Ko2 I should go with after ordering my .75"-2.5" Bilstein 6112 Front and B8 5100's in the rear. I ordered the shocks assembled at 2.5" for maximum ride height. I would like 305/65/18, but I'm unsure if they will even fit without 3+ lift. if they do fit, would it affect my speedometer or acceleration? Or 295/70/18, which I've read rubs on a 3". My goal is to make it look as stuffed as possible without cutting too much. Im going to be ordering Fuel Anza 18x9 Wheels 20 offset the same time I order the tire. Any advice helps! Thanks!
  2. Sep 18, 2020 at 4:19 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Rooskie[OP] likes this.
  3. Sep 18, 2020 at 5:15 PM
    SKB
    SKB New Member
    Shane
    CA
    2015 S/C Tundra CM 4X4
    295/70r18 will fit with the 2.5 lift. you will need to max out caster and push the front inner fender liner forward a bit. I'm running 35x12.5r18 like that.
  4. Sep 18, 2020 at 6:38 PM
    Blueknights75
    Ron
    Clayton, NC
    295 will fit perfect and meet your needs that you are wanting. The only two things you will have to do is remove the small front mud flap in front of the front tire as well as a little cutting on the skid plate.
  5. Sep 18, 2020 at 8:15 PM
    Welcome from NY.
    Do a search on here about those BFG's, some people had issues with getting them balanced. ;)
