Tire size
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by LB2016T, Jun 9, 2023.
  1. Jun 9, 2023 at 9:03 AM
    LB2016T
    LB2016T [OP] New Member
    2016 SB limited
    N/A
    Can I run 295x60x20 ttires on stock limited 20 in wheels with no modifications with norubbing ?
  2. Jun 24, 2023 at 11:25 AM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    I’m gonna assume no, I run 275/65r20 and needed a level and slight manipulation of the wheel well plastics. Our tire size is very similar but yours are a bit wider. Hope this helps
  3. Jun 24, 2023 at 11:37 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    If you post this question in the 2.5 thread you'll get a better response... Everyone here in the 2.5 Pro threads have a different suspension set up than you have in your rig.
    Also if you search around a bit, you'll find this question has already been answered numerous times.
    This link should get you started... Wheel & Tire Guide
    ATV25 likes this.
