Tire size with Leveling
Discussion in 'Wheels & Tires' started by Chance206, Jun 9, 2021.
  1. Jun 9, 2021 at 12:21 PM
    Chance206
    Chance206 [OP] New Member
    2019 Metallic Grey Tundra CM SR5 4x4
    Bilstein 5100 struts
    First post here and I'm liking what I've been reading. So to hopefully get some help for my very non knowledgeable self (and hopefully don't ruffle to many feathers) I have a 2019 CM SR5 4x4 with bilstein 5100 struts that I have set In the middle which gives me 2.25" I think it was. I'm looking looking buy new rims and tires when mine are due to be replaced. Right now I really like the Fuel Rebel 5. In the 20" size it comes in a 1 and 20 offset. Id like to have just a slight bit of tire sticking out from fender. It appears from research a 295/60-20 would be the size i would be best to go with. What about the wheel offset. Positive 20 sure seems it would put the tire fairly well inside the fender.
  2. Jun 9, 2021 at 12:47 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Stock rims are +60 so +20 is going to stick it out farther. I would stick to wheels in the +20 to +25 range, going down to 0 or 1 can cause rubbing issues and they will stick way out throwing rocks, dirt, mud all down the side of the truck.
    GODZILLA likes this.
  3. Jun 9, 2021 at 12:50 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    +20 fuel.
  4. Jun 9, 2021 at 1:21 PM
    Chance206
    Well ok then. What size tires are those Dan?
  5. Jun 9, 2021 at 1:24 PM
    Danman34
    Danman34 New Member
    Danny
    295/55/20. I’m at 2” and had minor rubbing that was easily fixed with a heat gun and reshaping the plastics. A 295/60 will be close, but you’re most likely going to need to do a bit more trimming.
  6. Jun 9, 2021 at 1:42 PM
    Chance206
    Well 295/55 might be what I need to look into. Your truck has exactly what I'm looking for
    Danman34 likes this.
  7. Jun 9, 2021 at 3:32 PM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    Are you running spacers as well
  8. Jun 9, 2021 at 5:27 PM
    Danman34
    Danman34 New Member
    Danny
    Nope.
  9. Jun 9, 2021 at 5:42 PM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    Damn..... I got 305/55 on the way to go on some 20x9 with +20 offset...... No way it will work if u had to trim with that
  10. Jun 9, 2021 at 6:41 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Go here: Check this out. I just mounted 305 70 17 on a +25 offset. Had about 2.25 front lift before I did it. Had to push plastic with a heat gun and remove all mud flaps up front. Comparing the 2 sizes I think you'll be fine.
    I had to use a CB shim with the middle setting to get 2.25 FYI.
  11. Jun 10, 2021 at 4:10 AM
    Danman34
    Danman34 New Member
    Danny
    Nope. Lol. It still rubs a little in reverse but not enough to bother me.
  12. Jun 10, 2021 at 4:14 AM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    Are those crush wheels
  13. Jun 10, 2021 at 4:23 AM
    Danman34
    Danman34 New Member
    Danny
    Fuel Tech
  14. Jun 10, 2021 at 4:44 AM
    Loose
    Loose New Member
    2020 Platnium
    295/60/20. +20 offset. No trim. No spacers. You will need good alignment and pay attention to caster. 20210218_164336.jpg
    TheGreyTundra28 likes this.
  15. Jun 10, 2021 at 5:15 AM
    War Machine
    War Machine SSEM # 5 3MW
    20x9 +20 offset, 295/55/20 on stock suspension. No lift or level, so you can probably go with the 295/60/20 or bigger with no problem. Had to trim a little plastic and remove mud flaps. My other Tundra had 33x12.5x20’s with a 3/2 level before I did a BMC and went to 35’s, so I’d assume you’ll fall somewhere in between the two.
    A89FA1D1-67BB-4F69-87B3-A8906E360757.jpg 23436111-F6F2-412C-908C-CC593F3AE0D6.jpg
    OMWTFYB likes this.
  16. Jun 10, 2021 at 9:03 AM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    Both of these look great. Exactly what I am after. Hope the 305 works. I do have the JBA uca's on the way to go with it. Hope that makes up the difference
  17. Jun 10, 2021 at 9:58 AM
    Danman34
    Danman34 New Member
    Danny
    How much are you lifting? If you’re doing 3” up front, you’ll probably be ok. If you’re doing 2”, like I am at. The 305 will require trimming. No way around it when it would be the same setup and wheel offset as me and I had to wirh a smaller tire. Not a deal breaker either way. Every problem has a solution. The new uca won’t change the suspension height any. But it will allow for more positive caster, which will get you away from the body mount but put the tire more into the bumper. That’s easily remedied by shimming the bumper
    Loose likes this.
  18. Jun 10, 2021 at 3:35 PM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    Riddle me this then.....and I am just asking, trying to learn, as this is the 1st truck I have lifted on my own..... If 305 is the width, what would more lift accomplish
  19. Jun 10, 2021 at 5:52 PM
    Loose
    Loose New Member
    2020 Platnium
    The wider the tire the more stuff it bumps into when you turn the wheel. The higher the truck the less stuff to bump into.
    I am Batman!
  20. Jun 15, 2021 at 9:13 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    I went with +1 fuel avengers. The difference between +20 and +1 is just 19 mm, more or less 3/4”. Divided by 2, its 3/8 on each side. With 275/55-20 tires sits 2” proud of the rear fender.
    My next tire will be 295/55-20 which is 3/4” wider than stock, again divided by 2, thats 3/8” on each side. My guess is that at the end they will be sticking out 2 3/8” off the fender. This set up is only good for non - off road truck.
  21. Jun 22, 2021 at 2:18 PM
    This is the way
    This is the way New Member
    Rthur
    i went with fuel tech +1,, gun metal, with gun metal center cap, with Bilstein 6112 high seting and 5100.. had 295-55-20, really didnt like how it looked on my truck for some reason. went down to 275-60-20 ko.. thanks Americas Tires for letting me exchange my tire with no cost, and a refund. next set will be either 285-60-20 or the 295-60-20.
    toyofan87 and Loose like this.
  22. Jun 22, 2021 at 2:48 PM
    Loose
    Loose New Member
    2020 Platnium
    Love it!!!
  23. Jul 19, 2021 at 6:40 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    Would love to have the part number off those center caps.
  24. Jul 19, 2021 at 9:22 AM
    This is the way
    Rthur
    i had americas tire call fuel to order them.. i ran into wheel caps on the fuel website by accident and thats how i knew about it.
  25. Jul 19, 2021 at 9:28 AM
    Greybeard
    Forsyth Georgia
    2014 SR5 Double Cab
    Did they possibly list the center cap part number on your receipt? I’m on a mission to find replacement caps since I lost one of mine. (Different brand) the wheel sites either don’t show part number and/or don’t show the backside of the caps for me to tell if they will work or not.
  26. Jul 20, 2021 at 8:03 AM
    This is the way
    Rthur
    wasnt able to find the receipt.. i have every other receipt, but not one for the caps..
  27. Jul 20, 2021 at 8:59 AM
    Greybeard
    Forsyth Georgia
    2014 SR5 Double Cab
    Thanks for looking
  28. Jul 20, 2021 at 9:33 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
  29. Jul 20, 2021 at 4:17 PM
    Hambone1
    Hambone1 New Member
    Blaine
    2015 tundr limited
    Not much yet
    Update on my truck...... Was changing oil and rotating tires. The new set were sitting in the corner waiting on the falkons. Couldn't help myself and had to try. They fit...... 305/55 R20 with +20 offset. Stock suspension. I removed front mud flap and at absolute full lock backing up I have a little rub.
    Now I don't know what to do about lift because the tires fill the wells perfect now and I don't want it to look dumb with a lift........ Real life problems.
