Tire Size Recommendations
Discussion in 'Wheels & Tires' started by DamnNearStock, Jan 4, 2023.
  1. Jan 4, 2023 at 6:08 PM
    DamnNearStock
    DamnNearStock [OP] New Member
    Jack
    2007 Crewmax SR5
    Bilstein 5100 2.25” front shocks 1” rear blocks
    Just got my bilstein 5100 shocks and a 1 inch rear block put on, and it just so happens to be time for new tires. been checking out the nitto terra grapplers, and i’ve gotten a quote for $1,250 with install for 275/65r18’s. after seeing several tundras with 285/70’s and even 295/70’s i’d like to go up in tire size. (probably just 285/70’s) but i’d like to know if anyone with a leveled tundra had any scrubbing with 285/70’s. thanks
  2. Jan 6, 2023 at 8:33 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    On my dads leveled gen 2 TRD OR he had 275/75/18 on stock rims. This is about an inch higher than stock and can still find tires that are not E load to save on weight. If you can fit 295/70/18, Nitto Recons come in SL to save weight and up in size. FWIW hope this helps
