Tire Size on a 2008?
Discussion in 'Wheels & Tires' started by Albinator, May 5, 2018.
  1. May 5, 2018 at 1:52 PM
    Albinator
    Albinator [OP] SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    Hey guys,
    I currently have 255 70R 18 tires on my truck with 9/11 tread left (Perelli’s) and was wondering is this the stock size? Discount Tire thought they come stock with 275 70R 18.
    I was also seeing how big of a tire I could fit on my stock Tundra with no leveling kit and they said a 285 70R 18 with no rubbing.
    Is this the case for both questions?
  2. May 5, 2018 at 2:16 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Question 1, yes they do come with 275 70 18’s
    Question 2, not sure. But if they say so it’ll probably fit
  3. May 5, 2018 at 3:32 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Albinator, 2008 stock tire size is P- 275/65/18. You can move up to 275/70/18's with no modding. Compare tire sizes here
    zcarpenter92 likes this.
  4. May 5, 2018 at 3:39 PM
    Albinator
    Utah
    Noticed on the inside of my door it shows 255 70 18. I would have to mod at 285 70 18?
    Yay or nay on a leveling kit messing up the trucks geometry and premature wear and tear?
  5. May 5, 2018 at 3:47 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    If done right, a leveling kit wont give you any premature wear.
    BTBAKER likes this.
  6. May 5, 2018 at 3:51 PM
    TheBeast The Beach
    I say level it and throw some 295/70/18. Great tire size for the Tundra.
  7. May 5, 2018 at 3:51 PM
    rons23
    Ron
    Kill Devil Hills
    I ran a leveling kit up front for 2+ yrs , because I had a itchy ass. I should have just waited until I could afford what I wanted to do. I would level with some Bilstein 5100's 360. Depends on what your doing with your Tundra . On that 285/70/18 you are 1.6" taller and 1.2" wider which could possibly rub on that control arm. I had no issues with my spacers,but my Tundra is a Street Princess
  8. May 5, 2018 at 4:14 PM
    Albinator
    Utah
    These? http://www.lowrangeoffroad.com/07-10-toyota-tundra-bilstein-5100-adjustable-ride-height-kit.html
    I’m just reading how leveling can affect towing, driving, etc.
  9. May 5, 2018 at 4:30 PM
    rons23
    Ron
    Kill Devil Hills
    mudslinger79 likes this.
  10. May 5, 2018 at 4:49 PM
    Albinator
    Utah
    Do you use your stock springs or would I need to get new ones? They won’t damage joints, etc?
  11. May 5, 2018 at 5:09 PM
    rons23
    Ron
    Kill Devil Hills
    With the 5100's you would use your factory spring's. I went with the 6112's which is a full coilover. No they won't damage joints . If you lift it over 3" then a differential drop is recommended to adjust with the change in the geometry .
  12. May 5, 2018 at 5:41 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Tag, Im curious also, i have stock and want to go to a bigger tire size, 275/70/18, but if i can go 285/70/18 without any mod i would definitely get that.
    Albinator[OP] likes this.
  13. May 5, 2018 at 5:43 PM
    Albinator
    Utah
    Do you have a link for the ones you got?
  14. May 5, 2018 at 6:00 PM
    rons23
    Ron
    Kill Devil Hills
    Here ya go. Guy's name is Darren Schmidt. I got mine assembled . You have a couple of options as far as height . I am running mine @ top setting of 2.5". There's a lot of guy's running @ the 1.9 " mid setting.
    https://www.boss4x4s.com/
  15. May 5, 2018 at 6:12 PM
    Albinator
    Utah
    Does the mid setting level it out? I saw this too in a video that you can only go so high depending on your model. He had the 05-06 model it looked like so I wonder if this stands true to my 08 4x4 Crew
  16. May 5, 2018 at 6:25 PM
    rons23
    Ron
    Kill Devil Hills
    I have an 08 DC, and my set- up is 6112's up front and 5100's in the rear with a 1" tapered block in the rear. This allowed me to move up to a 295/70/18 tire. I have a small rake left in the overall stance . If you go with 1.9 setting and leave rear stock you will be pretty close to level. Just remember if you load stuff in your truck with it level you will deal with some sag . That's why I chose to leave a little rake. If you do decide on 6112's, I would swap out rear with the 5100's or if you plan on going off-road some you could upgrade to the 5160's. You gave a good amount of options . I looked @ your Tundra and it looks like it needs some de-chroming haha. Black it out
  17. May 5, 2018 at 6:37 PM
    rons23
    Ron
    Kill Devil Hills
    As mentioned above , you can go up to 275/70/18, but a 285 will be iffy . Measure the inside of your front tire and see what you have in clearance to your control arm . If you have around an 1" chances are your gonna rub, unless of course you go with some wheel spacers.
  18. May 5, 2018 at 8:15 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    305 :anonymous:
  19. May 5, 2018 at 8:18 PM
    Ely010606
    SPARKS, NV
    Thanks Ron, greatly appreciated the advice, im just gonna stick to the 275/70/18.
    rons23[QUOTED] likes this.
  20. May 5, 2018 at 9:36 PM
    Albinator
    Utah
    So you’re just going to get that tire without leveling your truck (if that’s what you mean about no mods)?
  21. May 5, 2018 at 9:46 PM
    Ely010606
    SPARKS, NV
    Yes, im gonna leave it stock and get the 275/70/18, no plans of lift or level for now.
  22. May 5, 2018 at 10:03 PM
    Albinator
    Utah
    Yeah I may head that direction due to the cost of leveling and new tires but we’ll see. I hope the bigger tire size makes a difference in looks compared to our 255’s
  23. May 7, 2018 at 9:19 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I wouldn't go 285/70/18 on a stock tundra. I ran my 275/70/18 stock for a little bit and I think the 285's would definitely have rubbed.
    That said, they will make a huge difference in looks!! Here are a few pictures of when I had 255/70/18 and then went to 275/70/18, all before leveling.
  24. May 7, 2018 at 9:23 AM
    Albinator
    Utah
    Looks like the top pic is the 255 and the other two are the 275? That look does makes a difference! Have you noticed any mpg loss due to the bigger size?
  25. May 7, 2018 at 10:10 AM
    Ely010606
    SPARKS, NV
    Now for sure get the 275/70/18, thanks
  26. May 7, 2018 at 10:13 AM
    parker44
    parker44 New Member
    Correct, top pic is 255's and bottom 2 are 275's. I did notice about a 1-1.5 mpg drop with mine. You are going up an 1" in tire diameter, but also increasing the weight too. Those stock 255's are like 40 lbs and the 275/70's are all 10 ply, load E tires, which are usually 50+.
  27. May 7, 2018 at 1:14 PM
    Albinator
    Utah
    I’ll have to think it over. My Tundra got 15.6 mpg on the highway last fill up so I’m tracking it again from my last full up to see how it goes (and figure why it would be that low when it should be 17-18 I thought?). Would hate to lose more mpg
  28. May 7, 2018 at 1:25 PM
    parker44
    parker44 New Member
    These trucks are certainly not known for mpg. My truck never got over about 16-16.5 stock. A lot of these trucks I don't think get the "advertised" 18 on the highway. Some do, but I think the general consensus is they don't.
  29. May 7, 2018 at 1:49 PM
    mudslinger79
    Christopher
    Williamsburg, Va
    You'll get 18mpg at 55mph, with a tailwind, on flat land, good asphalt. Realistically, that ain't happenin'!! LOL
  30. May 8, 2018 at 8:57 AM
    Albinator
    Utah
