Tire size increase with stock rims and lift?
Discussion in 'Wheels & Tires' started by Imhyper, Aug 2, 2018.
  1. Aug 2, 2018 at 4:55 PM
    Imhyper
    Imhyper [OP] New Member
    Scott
    2017 Toyota Tundra SR5
    I want to level out my 17 tundra SR5 4x4 but want to keep the stock rims. I was told I can get a 2 1/2 inch/3 leveling kit for it and it would be fine but was actually thinking of going the 3.5 inch suspension lift. I don’t want the tires to look like they’re stuffed inside but I also can’t go too big of a tire with a stock rim . 285/75/18 maybe?
  2. Aug 2, 2018 at 5:05 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
  3. Aug 2, 2018 at 6:10 PM
    Imhyper
    Scott
    Yeah not what I was looking for though.
  4. Aug 2, 2018 at 6:11 PM
    Imhyper
    Scott
    I plan on lifting this truck up some
  5. Aug 2, 2018 at 7:00 PM
    Rcrv
    Rcrv New Member
    Connor
    Charlotte, NC
    2018 SR5 Crewmax Tundra Silver Sky 4WD 5.7FF
    I run a 285/75/18 on stock wheels. 2.5” level up front. It rubs a little on the front fender liner at full lock but only in reverse. 908D0143-4E51-4F32-B03E-20CD0AFE62B1.jpg
  6. Aug 3, 2018 at 4:59 AM
    Imhyper
    Scott
    Thank you very much! This is the answer I was looking for. Truck looks very nice
    Black Wolf likes this.
  7. Aug 3, 2018 at 5:23 AM
    I you do get some rubbing on the front fender liners.....they are easy to move forward.
    Imhyper[QUOTED][OP] likes this.
  8. Aug 4, 2018 at 1:16 AM
    Imhyper
    Scott
    Anyone with a 3 1/2 in. lift with stock rims? Looking for a visual
  9. Aug 4, 2018 at 8:12 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    On a 3.5”, I’d go bigger than 285’s. I’m inclined to believe you could do 35’s on that lift. You’ll just need 1.25” wheel spacers on the stock rims.
    HighDesertSurfer and Imhyper[OP] like this.
  10. Aug 4, 2018 at 8:27 AM
    Imhyper
    Scott
    Yeah thanks that’s what I’d like to do is go to a larger tire size but I just want to make sure they fit on the stock rims. I believe the rims are 8 x 18 if I’m not mistaken
  11. Aug 4, 2018 at 8:37 AM
    ninjajay
    Spoolston, TX
    Despite the thread title the first post describes exactly what you're looking for.
  12. Aug 4, 2018 at 9:09 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Yup...
    Imhyper[OP] likes this.
  13. Aug 5, 2018 at 7:22 AM
    Imhyper
    Scott
    You are correct. I looked over it too quickly. Thanks
  14. Aug 10, 2018 at 9:35 AM
    Old Alan
    Old Alan New Member
    San Jose
    2017 SR5 Crewmax
    Toytec Boss lift, Black Rhino Warlords wheels, 295/70/18 Nitto Ridge Grapplers, SDHQ Sliders, RBP grill, color matched surround and bulge, Kendwood head unit.
    The before pic is my stock 18" SR5 wheels and tires on a ToyTec Boss lift, not maxed to 3".
    The after pic is 18" Black Rhino Warlords with a 12 offset. The tires are Nitto Ridge Grapplers at 295/75/18. Same lift. I had to cut and bend some inner fender plastic.
    Hope that helps some.
    Imhyper[OP] and zcarpenter92 like this.
  15. Aug 10, 2018 at 10:50 AM
    Imhyper
    Scott
  16. Aug 10, 2018 at 10:51 AM
    Imhyper
    Scott
    Yes it does, thank you very much. If I go with the rough country 3 1/2 inch lift I should be perfect with those sized tires without any trimming I imagine.
