Tire size help
Discussion in 'Wheels & Tires' started by buzat, Jan 22, 2021.
  1. Jan 22, 2021 at 7:13 PM
    buzat
    buzat [OP] New Member
    I have searched the forums over and over and i cannot get a definite answer.
    I am about to purchase tires for my 2016 SR5 crewmax on the stock 20s, i just installed a 2" leveling front kit and would like to put the tallest and widest tires on, i have already removed the mud flaps and don't mind very minor rubbing which i can use a heat gun to fix.
    I was looking at 305x55/20 but they do not look tall enough, the width is good but i would like them a bit taller. Please help
  2. Jan 22, 2021 at 7:21 PM
  3. Jan 22, 2021 at 8:59 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    This^^^^^^ :thumbsup:
  4. Jan 23, 2021 at 5:41 AM
    buzat
    Thanks, i did go to that site but i am still ignorant to those specs, i would much rather hear from the ppl who actually have them on their trucks,another thing i forget to mention, i have fender flares on so i would like to get the tires extended out to the flares and tall enough to close the huge gap in the wheel well.
    Anyone with 2'' front lift looking like that and what are issues you run into?I am looking at 3 sizes, 305x55/20,295x60/20 or 33x12.5/20,What do you suggest. Thanks
  5. Jan 23, 2021 at 5:52 AM
    buzat
    This is before lift and chrome be gone lol i will post pics when all is done[​IMG]
  6. Jan 23, 2021 at 5:59 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Tundras fit 33 inchers stock, so if you install 33-34 inch tall tires with your lift you will be good to go. Width matters however as does wheel offset. The 12.50 width could cause some rubbing or issues. If you stick with metric LT tires around 11 to 11.5 inches wide you should be good.
    Use this to see the width and height- just plug in the tire size you are considering. It is not perfect since tire manufactures may be a touch shorter/taller etc but it will give you the basic info you need
    KWC likes this.
  7. Jan 23, 2021 at 2:42 PM
    buzat
    Got it, thanks a mill. I am going with 295x60/20. Its tall enough i wish it were a bit wider but almost a full inch wider than stock so it should be ok.
    Thanks again. Will post
  8. Jan 23, 2021 at 2:55 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Check your clearance on the UCA. That is what I would be most concerned with going wide. I am going taller and 1/2" narrower than OEM 285/55/20. With that tire I have a 1/2" clearance at the UCA.
    BravoDeltaRomeo likes this.
