Tire rubbing ?
Discussion in '3rd Gen Tundras (2022+)' started by jrm0405, Apr 17, 2023.
  1. Apr 17, 2023 at 11:55 AM
    jrm0405
    jrm0405 [OP] Say hello to my little friend
    Woodbury, MN
    2022 Supersonic Red Tundra Limited
    De-chromed everything except window trim, Method 707 wheels, Falken 285/70/18 AT3,Rough Country 2" strut level, Heritage Grill, Dynamic Diode Light Bar, Rough Country fender flares
    Why would a 285/70/18 rub only on one side, it rubs on a small corner of the frame in the wheel well. Just curious.
  2. Apr 17, 2023 at 11:57 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Every truck will have some variation in gaps, spaces and tolerances. It's a Toyota, not a Rolls-Royce.
    Alignment, air pressure, level ground, would also come into play.
    Once you vary from stock size and parts, all bets are off.
    nodak67 likes this.
  3. Apr 17, 2023 at 12:47 PM
    nodak67
    nodak67 New Member
    JR
    yeah you are not driving a f-1 car were .01 tolerance or smaller is required.
    and a side note, until a f-1 car is warmed up, you technically couldnt turn the engine over since its pretty much frozen (seized)
  4. Apr 17, 2023 at 6:04 PM
    jrm0405
    Woodbury, MN
    That makes sense and answers my question. Thanks
  5. Apr 18, 2023 at 8:15 AM
    worksjo
    worksjo New Member
    2023 Tundra SR5 Off Road
    Are you actually rubbing frame or just the mud flap? I did 295/70/18 and it rubbed the mud flap. The drivers side did seemed to rub more, maybe there is some difference in how the mud flaps are molded from driver to passenger side.
    I removed the front flaps and pulled back the felt inner wheel well a little and there is lots of space at least an inch in the tightest spot and both sides seem the same. That said I did go with a different offset wheel and it’s the TRD OR suspension so maybe it’s different.
