Tire Rub
Discussion in '1st Gen Tundras (2000-2006)' started by Skilo, Nov 26, 2021.
  1. Nov 26, 2021 at 9:37 AM
    Skilo
    Skilo [OP] New Member
    I have a 2005 SR5, I replaced the stock tires with 265 70 R17 tires and rims and they rub on the front. The question is will all tundra rims fit a Toyota regardless of year. Thanks
  2. Nov 26, 2021 at 9:41 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    2000-2006 wheels are six lug and will fit. Other Toyotas such as Tacomas and 4Runners use six lug wheels as well.
    07-21 Tundra wheels will NOT fit. They are five lug.
    2022 Tundras are bringing back six lugs, but it's too early for anyone to have tried those on a 2000-2006.
    Darkness and FrenchToasty like this.
  3. Nov 26, 2021 at 12:19 PM
    shifty` Animals and insects don't do drugs
    Probably important to mention also, wheel offset between different (non-2000-2006 models) OEM wheels, so there are two risks associated with running wheels from a different model or year (i.e. from something other than 2000-2006 Tundra):
    - The wheel offset may put the rim further inward or outward, which may cause rub
    - Tire sizing may no longer match what came stock for the vehicle, may need to adjust down tire size or add spacers to correct
    des2mtn[QUOTED] likes this.
  4. Nov 26, 2021 at 1:56 PM
    Wildcat_007
    Wildcat_007 New Member
    2005 Tundra 4wd Double Cab SR5
    17s touchscreen camera air raid Borla
    I have a 2005 Tundra DC 4wd adding 265/70/17s trying to use 2019 Tacoma TRD wheels am I going to have a clearance problem on the front ?
    on this site calculator this is goin to be OK
  5. Dec 1, 2021 at 8:51 PM
    Wildcat_007
    The 265/65/70s on 2016-2019 Tacoma TRD 17" Rims cleared the Upper Control Arms (UCA) by a pinky ... was an index finger clearance before with stock 17" rims and 265/65/17s ... so
    I added 1.25 " Wheel spacers ... now can fit my hand in between rim and UCA and tires sits just inside wheel well fender flares.
