Tire rub
Discussion in 'Wheels & Tires' started by Grubblife18, Oct 4, 2017.
  1. Oct 4, 2017 at 8:28 AM
    Grubblife18
    Grubblife18 [OP] New Member
    2014 tundra limited
    6" readylift, rock star wheels on 33's and much more.
    Can anyone give me some hints on how to prevent rub with a 20” wheel and 33/12.50 tire. Only rub when wheel is turned all the way. I know you can trim wheel well back but I didn’t think I should have to with 6” lift.
  2. Oct 4, 2017 at 8:31 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You have a 6” lift and you’re rubbing 33’s? o_O What’s your offset and where are you rubbing?
    Prostar 190 and 4x4_Angel like this.
  3. Oct 4, 2017 at 8:16 PM
    Grubblife18
    2014 tundra limited
    They are 20x10’s. I should have gotten 20x9’s. Rubbing as I turn wheels all the way to one side or the other. Trimmed back the inside of both wheeel wells. Hope it works
  4. Nov 10, 2017 at 7:46 AM
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
    More than likely your rubbing the cab mount. Search CMC, or cab mount chop.
  5. Nov 10, 2017 at 8:11 AM
    Xf3lixdcatx
    Xf3lixdcatx New Member
    Satan
    Enterprise, AL
    Stock baby
    ditto. +1 Had the same issue.
  6. Nov 10, 2017 at 9:29 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Could be the portion of the wheel well liners to the rear of the tires. Could also be the skid plate. Could also be the rear lip of the bumper. I had to trim or heat mold all those parts when I put my tires on.
    It was annoying AF.
    Crewmax Chris likes this.
  7. Nov 10, 2017 at 11:23 AM
    Crewmax Chris
    Crewmax Chris Paper Airplane Enthusiast
    Lewiston, ME
    2013 Tundra SR5 DoubleCab
    I got the skid plate with mine...definitely check that.
