tire rub upper control arms / need a better fitment wheel to prevent this?
Discussion in 'Wheels & Tires' started by trace2003, Jun 10, 2015.
  1. Jun 10, 2015 at 12:01 AM
    trace2003
    trace2003 [OP] New Member
    2003 Toyota Tundra limited TRD
    2 inch leveling kit up front / 1 inch rear /Tires 285/75/16 They rub upper control arm / I tried spacers not enough thread/ any one no of a wheel that will work to back me off that upper control arm?
    hello all,
    I have a 2003 Toyota Tundra 230,000 miles on my 4.7 L V8 2 inch leveling kit up front 1 inch in rear. stock wheels 6 lug 16 inch. although my issue I am running 285/75/16 which cause rubbing of the upper control arms. I tried 1 inch spacers, not enough thread to hold on! Does anyone have a solution to my wheel replacement issue! or if I could find the wheel studs longer for the adapters? a few of the best things I've done replaced all fluids for lube with full synthetic/ drive shaft failed from no grease zerts? Ron's Machine Shop in Utah chop the ends and replaced with grease able Dana U Joints. Bed Rug, always/ gun safes mounted in the cab also in the bed, regular preventative maintenance service. I live at the beach so salt air is always present.
  2. Jun 10, 2015 at 6:18 AM
    Try ones of these:
    -Try 1.25" spacers and ET lug nuts
    -ET (extra turn) lug nuts
    -Aftermarket UCA's
