Tire Rotation Question
Discussion in 'Wheels & Tires' started by RickPlatinum2020, Mar 23, 2022.
  1. Mar 23, 2022 at 5:08 AM
    RickPlatinum2020
    RickPlatinum2020 [OP] New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    What is the general consensus on tire rotation? I have done the X pattern on all my previous vehicles every 5000 miles. The manual for my truck says to only switch the front with the rears, that is what I have done since new. About 4000 miles ago I picked up a set of 18 inch TRD wheels with the Michelin tires, want to make sure I get the most out of them. Appreciate your responses.
  2. Mar 23, 2022 at 5:13 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I stopped the x rotation years ago. I just do front to back, back to front. I have not noticed any tread life difference in all honesty and that’s been with various different vehicles.
  3. Mar 23, 2022 at 5:14 AM
    Front to back rotation is what I’ve done per last few vehicle service manual recommendations. Should be fine to X pattern as well with modern radial tires. Old bias plys would sometimes bunch up when rotation direction was changed.
  4. Mar 23, 2022 at 5:19 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    DF to DR, DR to DF
    PF to PR, PR to PF
    I've seen people swap DR with PR, but I just do fronts to rears.
  5. Mar 23, 2022 at 5:21 AM
    Justbass
    Justbass New Member
    Steven
    Ohio
    2020 Platinum
    TRD Sway bar, Lomax Tonnueau cover, Bed rug, Havoc HS2 Steps, Tech 12 Volts stereo upgrade, Yakima bed extender, misc trim and bling,
    Radial tires are front to back, Bias ply tires are the x rotation. Been that way since radial tires hit the market in 1946
  6. Mar 23, 2022 at 5:26 AM
    NDTundra18
    NDTundra18 New Member
    Andrew
    Fargo, ND
    2021 SR5 MGM CM
    I’ve always done an X pattern but reading these comments is going to make my next rotation a bit easier!
  7. Mar 23, 2022 at 5:28 AM
    Taco-Spike
    Two Trucks
    Front to back
  8. Mar 23, 2022 at 11:22 AM
    RickPlatinum2020
    Rick
    Eastern PA
    Thanks for the responses. All our cars of late show X pattern, including 2020 Acura RDX, but I saw the front to back only in the Tundra manual.
