Tire Rotation Pattern
Discussion in 'Wheels & Tires' started by DaveInTexas, Mar 21, 2024.
  1. Mar 21, 2024 at 11:25 AM
    DaveInTexas
    DaveInTexas [OP] New Member
    Dave
    West Texas
    2020 Tundra SR5 + 2003 Tundra SR5
    The 2020 has a Ranch Hand front brushguard/bumper
    I rarely use 4WD.
    My left rear wears fastest.
    Have been looking at this:
  2. Mar 22, 2024 at 8:26 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Manual states just front to back, not crossing side to side. I have been doing that now for 43k with no abnormal wear
    DaveInTexas[OP] likes this.
  3. Mar 22, 2024 at 8:35 AM
    joe_from_iowa
    joe_from_iowa New Member
    Iowa
    2021 Tundra Double Cab SX
    Peeled off the SX stickers from the bed sides. Tyger running boards. A.R.E. DCU topper
    I'm going to cross mine over next time as I'm getting some outer tire wear on the right front. Same as my old tires and I had it aligned with the new tires.
  4. Mar 22, 2024 at 10:19 AM
    boatsnbikes
    boatsnbikes New Member
    I usually do front to back and swap sides on every 5th rotation. Supposedly with radials you don’t have to swap sides, it’s just the way I have always done it
  5. Mar 22, 2024 at 3:29 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    On the Tundra it's rear straightforward, fronts switch sides to the rear. If you rotate this way every time you will have the most even tread wear.
