tire/rim other questions newbie
Discussion in 'Wheels & Tires' started by TRD207, Jan 10, 2022.
  1. Jan 10, 2022 at 5:32 PM
    TRD207
    TRD207 [OP] New Member
    Hello,,,my first post here. Im on my 2nd tundra now,,,a 2019 double cab TRD off road limited that I bought new 3 years ago. It now only has 17,000 miles on it. It still has its original 18" rims and the 275/65-18 michielins. Actually I havent done anything to it besides put a plow on it when it was new. Next year I was thinking about putting on a dirty deeds 8 or 10" cat back,a tonneau cover and it will need tires. Id like to get the front end up a little so I was also looking at the 5100 bilstiens or pucks. Either level or if it still had a little forward rake,,I just dont want the front higher than the back.I really dont take it off roading. So 1st question which is better, front shocks or pucks? 2nd is after that how much taller tire can i go without rubbing? Thanks
  2. Jan 10, 2022 at 6:06 PM
    Shocks will definitely ride better. You can level the front with Bilsteins.
  3. Jan 10, 2022 at 7:23 PM
    Welcome from NY.
    Bilstein 5100's on the middle setting.
  4. Jan 11, 2022 at 6:10 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Get some Billys and level, upside your tires 1-2 sizes (265/70 or 275/70) and get DD 10"...you're set than!
  5. Nov 29, 2022 at 2:51 PM
    TRD207
    I did put on the bilsteins on the front and put them on the middle setting. Still has original 265 65-18 tires but its time for some new ones. Will a 285 70 18 fit without any rubbing? thanks
  6. Nov 29, 2022 at 2:57 PM
    HulkSmurf14
    2014 Tundra Limited
  7. Nov 30, 2022 at 4:54 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
  8. Nov 30, 2022 at 3:36 PM
    TRD207
    Think Ill go with 275/70-18. 285's dont seem to be very common.Found some but dont like any of them. looking at falken rubitreks AT.
    Jaypown likes this.
