Tire repair question.
Discussion in 'Wheels & Tires' started by cornwall325, Nov 28, 2018.
  1. Nov 28, 2018 at 6:49 AM
    cornwall325
    cornwall325 [OP] Work in Progress
    2018 Tundra TRD Offroad Limited Crewmax
    Question for all of you guys who have experience in tire repair. I have a pinhole that needs repaired on a rear tire. The spot is next to the colored looking bubble in the picture. The hole is literally the size of a pinhole closest to the bubble. Can this be repaired and if so what method do you guys suggest?
  2. Nov 28, 2018 at 7:18 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Plug it.
  3. Nov 28, 2018 at 7:29 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I don't think the tire place will fix it because it's on the side.
  4. Nov 28, 2018 at 7:29 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Generally, you should not plug holes in the sidewall. But that’s very close to the tread, so tough call.
  5. Nov 28, 2018 at 7:53 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I agree with most of the above. Liability has changed the rules for tire repairs. Not only can sidewalls not be repaired, an in or so in from the sidewall will no longer be repaired. Tires 5 yrs. or older are no longer repaired either. I think the tire in question will make a great spare though.
    NewImprovedRon likes this.
