Tire PSI (Cold vs hot)
Discussion in 'Wheels & Tires' started by Ghost Rider, Jun 22, 2022.
  1. Jun 22, 2022 at 10:50 AM
    Ghost Rider
    Ghost Rider [OP] Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Would someone enlighten me on the current possible tire PSI you have? Cold vs hot and what tire size?
    Mine are factory stock 20' running cold 34/35 and hot 42/43.
    Have a feeling my hot is too high, but want to compare some numbers before I let it out and re-air this weekend.
  2. Jun 22, 2022 at 11:27 AM
    AZBoatHauler
    So.Arizona
    Everything is based on cold numbers. I believe the factory recommendation is 30/33. Check the driver door jamb for the sticker.
  3. Jun 22, 2022 at 11:57 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Ah. But in real life? I know factory numbers are by sticker, but what of real life PSI people are running?
  4. Jun 22, 2022 at 11:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    tire pressure is always set cold. If you are running stock load and size, just follow sticker in door jam. I usually bumped it up a pound or two from factory specs, tires wore better.
    Then if you ever install larger tires or tires with a different load rating, use this tool to get your pressure
    AZBoatHauler likes this.
  5. Jun 22, 2022 at 11:59 AM
    Hot I run 44 psi on all corners with 285/70/18 Ridge Grapplers.
  6. Jun 22, 2022 at 11:59 AM
    AZBoatHauler
    So.Arizona
    If you are on stock tires and wheels that will give you the best ride. IME people change pressure when the change tire rating or are towing/hauling. Lower than OEM spec and you’ll wear the shoulder prematurely- higher the OEM spec with stiffen the ride.
  7. Jun 22, 2022 at 12:00 PM
    AZBoatHauler
    So.Arizona
    ^ Like these are E rated tires with max pressure of 80 psi - can’t compare to the p rated tires that come on the truck.
