Tire pressure?
Discussion in 'Wheels & Tires' started by CHEF, Apr 6, 2019.
  1. Apr 6, 2019 at 9:56 AM
    CHEF
    CHEF [OP] New Member
    MD
    2015 Silver Tundra sr 4.6
    First off, sorry if this has been covered here I've scoured the far reaches of the earth and can't find a definite answer.
    I have nitto ridge grappler 295/55r20 tires on a 2015 DC.
    The pressure is set to about 35 on the front and rear.
    The tire says max pressure 80psi.
    Should I add more or keep it at 35?
    JoshuaA likes this.
  2. Apr 6, 2019 at 9:59 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    When its dry, Go down the highway for a half hour or so. Pull off and put your hand across the tread. If it's cold on the edges too much pressure. If it's hot on the edges too low of pressure. You want the tires to be the same temp all the way across the tire tread.
    Otaku4life69 and JoshuaA like this.
  3. Apr 6, 2019 at 10:08 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Also seen some threads here on using chalk to make sure tire pressure is good.
    15whtrd likes this.
  4. Apr 6, 2019 at 10:09 AM
    Racingjohndeere55
    I just found the temp thing worked for me
  5. Apr 6, 2019 at 10:12 AM
    Racingjohndeere55
    I had a gmc 4/4 that had 28psi in the front and 24 in the rear
  6. Apr 6, 2019 at 10:40 AM
    MER
    MER New Member
    18' Limited CM 4x4 Off Road
    Just for comparison...
    I bought a stock used set of the 20” TSS wheels that came with BFG KO2’s LT285/55/20’s. The tires’ max pressure cold is at 65 psi and I’m running 49 psi on both front and rears.
    I too was unsure of what psi to run until another member on here sent me a pic off the door sticker on their stock TSS.
    I know you’re running Nittos... just wanted to give you a comparison.
    revtune likes this.
  7. Apr 6, 2019 at 10:50 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Ooh, this thread reminded me to check springtime psi on my NRG’s, thanks!
    I’m usually around 42 front/40 rear (empty bed), and 50/50 when I tow our camper. 35-40 over winter and freezing rain. Confirmed with chalk and hand method. I usually take a short jot on the expressway as speed changes the flatness of the tire.
    15whtrd likes this.
  8. Apr 6, 2019 at 11:02 AM
    15whtrd
    15whtrd Mr. Blonde
    I am a psycho, I check them once a month.
    jeremyd, Law323 and JoshuaA[QUOTED] like this.
  9. Apr 6, 2019 at 11:07 AM
    CHEF
    MD
    Thanks for the help!
  10. Apr 6, 2019 at 12:29 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I’ve found most people run 35-45 on their AT/MT’s
    revtune likes this.
  11. Apr 6, 2019 at 1:09 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Since that’s an e load tire, try going up to 40psi and see if you like it.
  12. Apr 6, 2019 at 1:24 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    That’s pretty good, so for math sake, that’s a 50% increase in psi compared to the spare. I know they are different sizes but it gives people an idea of what psi to run in an E rated tire in relation to a P rated tire. Does your truck ride pretty good? If the windows are down are you gonna bounce out of the truck:D
  13. Apr 6, 2019 at 1:44 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    35 seems low to me. I have the same size tires except they are toyo rt, and I run 45-50. Mine are load range e (10 ply), are yours? I use 40 on my work truck and they are "p" tires.
    revtune likes this.
  14. Apr 6, 2019 at 2:08 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Nitto Terra Grapplers. 275/60/20's P load rated. I'm running 45psi front and rear. 46,600 miles and the wear is even across all of them.
  15. Apr 6, 2019 at 3:48 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    LT305/65-18 Falken Wildpeak AT3s. 10 ply E rated. I'm running 40 psi in all four tires. This is what Les Schwab tires recommended. Seems to be good wear so far.
  16. Apr 7, 2019 at 8:53 AM
    CHEF
    MD
    They are E rated 10 ply.
    Hondoman[QUOTED] likes this.
  17. Apr 7, 2019 at 4:52 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    I run 33 in front and 35 in rear. 40 when I tow my boat. I have 29/65/20. I called Nitto and they are the ones that told me what I needed to run. Give them call.
  18. Apr 8, 2019 at 9:19 AM
    CHEF
    MD
    From Nitto....
    Regarding your inquiry, based on the vehicle information you provided, the recommended replacement psi for the Ridge Grappler is 39 psi for front and 42 psi for the rear tires.
    DM 2018 Tundra likes this.
  19. Apr 8, 2019 at 11:59 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
  20. Apr 8, 2019 at 12:46 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Here's what I've found. The bigger the boobs the more heavy duty the bra. So when she's stacked like a brick shit house you need all the help you can get to set those puppies in motion. Again, I run 45 psi in my Nitto's. Sorry but there simply is NO deconstructing my argument. :);):D:p:rofl:
  21. Apr 8, 2019 at 1:13 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Bridgestone KO2 AT and they put this over the factory recommended pressure since they added the AT tires as an upgrade. 49 psi is what I’m running as suggested.
    revtune likes this.
  22. Apr 9, 2019 at 2:37 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    42 psi all the way around in my E rated Conti's.
