Tire pressure - OBD Fusion app
Discussion in 'Wheels & Tires' started by TTund16, Sep 28, 2022.
  1. Sep 28, 2022 at 6:07 PM
    TTund16
    TTund16 [OP] New Member
    Can you read tire pressure (PSI) with the obd fusion app if you purchase the extended PID package?
    Even for the 2016 models (like mine), tire pres values are available on the bus but are not displayed. Toyota started displaying them on later models (2018? and newer models).
    btw, I also tried to program my friend's UltraGauge to no avail. The equations are available but I gave up after so many tries.
    Later versions of ScanGauge can also display tire pres even on 2016 models. or you can pay $ and update your old firmware to read tire pres ... That confirms that the data is available on the bus but not displayed on older models.
    I read bunch of threads and couldn't find any info.
    Anyways, I have provided more background info regarding scangauge and ultragauge but but my main question is regarding obd fusion app and if you guys can read tire pres.
    Thanks for coming in and we appreciate your support. :D
  2. Oct 9, 2022 at 10:21 PM
    TTund16
    I am told tire temperature is also available on the bus but not displayed in older models. So you should be able to read that as well. Has anyone tried that with the odb fusion app?
    I like to monitor the temperatures and see if I need a tire cooler kit! ;)
