Tire pressure monitor shows horizontal lines
Discussion in '2.5 Gen Tundras (2014-2021)' started by 18tundrasport, Dec 23, 2017.
  1. Dec 23, 2017 at 5:07 PM
    18tundrasport
    18tundrasport [OP] New Member
    PA
    2018 tundra dc sport 4x4 super white
    Lund step bars, afe filter, Trd flow accelerator
    When I use the info center to see the tire pressures it just shows horizonal lines? ???
  2. Dec 23, 2017 at 5:34 PM
    RonW
    RonW New Member
    Like all the time? Mine does it if its real cold but they usually register after a few minutes of driving. I've only noticed it in the cold though. And I've only had it 6 or so weeks...and I live in Mississippi....so it doesn't happen often.
  3. Dec 23, 2017 at 5:37 PM
    RonW
    RonW New Member
    Also, I don' get any low pressure warnings or anything when it does it.
  4. Dec 23, 2017 at 5:38 PM
    18tundrasport
    PA
    I will have to check it again but i thought it would show the pressures right away when the truck starts. It's about 40 Degrees here
  5. Dec 23, 2017 at 5:39 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I think you have flat tires
    BlueBottle likes this.
  6. Dec 23, 2017 at 5:40 PM
    18tundrasport
    PA
    Square tires
  7. Dec 23, 2017 at 5:43 PM
    RonW
    RonW New Member
    Yes, mine normally shows right away. Or by the time I scroll over anyway. It only does it when it gets cold.
    I have round tires though so it might not be the same.
    joonbug and MotoTundra like this.
  8. Dec 23, 2017 at 5:48 PM
    joem1cha3l
    Albany, NY
    This made me LOL ha
    MotoTundra and 18tundrasport[OP] like this.
  9. Dec 28, 2017 at 5:26 AM
    TTund16
    TTund16 New Member
    is the tire pressure display for 2017 or 2018 cars? I have a TPMS but don't recall seeing any pressure display!
    RussellVaughan likes this.
  10. Dec 28, 2017 at 8:59 AM
    RonW
    RonW New Member
    Mine is a 2018.
  11. Dec 28, 2017 at 9:03 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Curious also on the 2017.
  12. Dec 28, 2017 at 9:09 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Between the,
    Tire pressure Light
    Windshield washer fluid Light
    Maintenance required Light
    it is as if I have a Christmas Tree on my dash...
    Luckily no 'Check engine' lights.
  13. Dec 28, 2017 at 9:31 AM
    18tundrasport
    PA
    2018 if you page over to vehicle it shows all four corners of tire pressures
  14. Dec 28, 2017 at 9:41 AM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    I'd guess it has to do with the low temps we are having right now. I know my pressures are down about 4-5 lbs with the cold. I've never checked mine right on start-up, but every time I've looked at mine, it's had the pressures displayed.
  15. Dec 28, 2017 at 9:47 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    this alone makes me want to buy an '18
  16. Dec 28, 2017 at 9:55 AM
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    Same here...
    Isn't it just a light which illuminates when the pressures hit a certain number?
  17. Dec 28, 2017 at 11:03 AM
    RonW
    RonW New Member
  18. Dec 28, 2017 at 11:06 AM
    RonW
    RonW New Member
    It did take about a minute to register after I started the truck. So maybe I was wrong and it doesn't come on right away. But it is colder today too. We shall test this again and again until I get an answer.
  19. Dec 30, 2017 at 7:27 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    You're running 30 psi?? I have 20's and BFG's and I run 48 all around.
    NewImprovedRon likes this.
  20. Dec 30, 2017 at 7:28 PM
    netranger6
    Jeremy
    Mine doesn't show a pressure unit I start to roll a little bit. Not just sitting there on first start up.
  21. Dec 30, 2017 at 8:22 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    The reason is that to conserve battery life on the sensors, the sensors go into sleep mode when they stop moving. So when you start driving, they have to wake up, and connect to the truck before you get a reading.
    cnoyes72 and Laz1388 like this.
  22. Dec 30, 2017 at 8:45 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    Well DAMN - I don't have this on my 17 and i have bitched about this forever! My wife's jeep (2015) has it, my son's jeep has it, my wife's work car, subaru has it. I would love to have it on my tundra.
  23. Dec 31, 2017 at 3:28 AM
    RonW
    RonW New Member
    It sits at about 33 cold when I use a gage. The door sticker says 30/33
  24. Dec 31, 2017 at 3:32 AM
    RonW
    RonW New Member
    Well that makes sense now. It seems to take about a minute after I start the truck. I have been scrolling to that screen first thing since I've been watching it. Doesn't matter if I'm rolling or just sitting.
  25. Dec 31, 2017 at 5:56 AM
    18tundrasport
    PA
    This :bananadance:
    KB Voodoo likes this.
  26. Dec 31, 2017 at 6:51 AM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Replace the head unit....the Kenwood 9904 will tell you more about the truck than the center cluster does
  27. Dec 31, 2017 at 9:20 AM
    TTund16
    TTund16 New Member
    for the older models with no psi display,
    if the pressure gets too low there should be a warning light or a message. I haven't read the manual.
    there was another thread about this. tires must get very low (guessing in very low 20's) for the warning.
    it helps when if u are driving and/or not paying attention but if the tires are that low you can tell by looking at it!
    it is a good gadget but the psi display is a better gadget!
  28. Dec 31, 2017 at 9:48 AM
    Cuzican
    Cuzican New Member
    Louisiana
    My dummy light in my 17 goes off a lot higher than 20 psi, more like 28 psi, it's actually quite annoying. I've been driving for 25 years and never needed it before, wish I didn't have to have it now.
    geno0506 likes this.
  29. Dec 31, 2017 at 10:01 AM
    TTund16
    TTund16 New Member
    28 seems a bit too early considering many run theirs at 30 or even lower if off road!
    I need to do a test with mine.
  30. Dec 31, 2017 at 11:11 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    My 2016 OM does not give a number...it only says, "As an added safety feature, your vehicle has been equipped with a tire pressure monitoring system (TPMS-tire pressure warning system) that illuminates a low tire pressure telltale (tire pressure warning light) when one or more of your tires is significantly under-inflated." However, I had a low tire warning and could not tell which tire it was without a pressure gauge, until the next morning when it was flat. I also remember that after the tire was fixed, I drove a few feet and the TP warning light reset itself (this is also in the OM). I still check my tires once a month with a gauge...
    TTund16[QUOTED] and driverdog like this.
