Tire Pressure Help
Discussion in 'Wheels & Tires' started by okk3n, Sep 18, 2024.
  1. Sep 18, 2024 at 8:34 AM
    okk3n
    okk3n [OP] New Member
    2024 Sr5 4x4 CrewMax 5.5 with Toyo Open Country A/T III LT315/70R17 121/118S
    I used this calculator and it says to run them at 35. Is that correct? I bought the truck used and I have never owned non-OEM spec tires on any of my vehicles. Thanks!
  2. Sep 18, 2024 at 8:42 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    That calculator is good and puts pressure in the ballpark when switching to different load or size tire. You might adjust it a pound or two, depending on how you load and use your truck.
    Pressure sound about right, I ran 34/35 depending on load with metric 33s and now run 35 or 36 with metric 35s. I think you are good.
    You can also perform a chalk test to confirm.....just search for how to do that, super easy and vids on youtube will walk you thru it.
  3. Sep 18, 2024 at 8:43 AM
    okk3n
    Thanks! 90% of the time she will be a grocery and family hauler lol
