Tire Pressure Dilemma
Discussion in 'Wheels & Tires' started by Toyfosi, Sep 20, 2020.
  1. Sep 20, 2020 at 5:07 PM
    Toyfosi
    Toyfosi [OP] New Member
    Tom
    Calvin, KY
    2010 Tundra
    Trailer brake,
    My 2010 Tundra has the 18" alloy wheels with P275/65R18 tires and Firestone Transforce HT tires. The tires have 80 psi. maxon the side but when I bought the truck they had 50 psi. in them. Firestone website said go with mfgr recommended pressure which is 30 and 33psi. What do you guys think?
  2. Sep 20, 2020 at 5:11 PM
    Go with the sticker on the side of the door
    YardBird likes this.
  3. Sep 20, 2020 at 5:11 PM
    80 is way too much.
    BravoDeltaRomeo and YardBird like this.
  4. Sep 20, 2020 at 5:15 PM
    No way I would have 80 psi in mine unless towing at max capacity.
  5. Sep 20, 2020 at 5:19 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How often are you hauling? Flat country or canyon roads?
  6. Sep 28, 2020 at 7:57 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    80 psi is the max pressure the tire itself can contain when hot and under load before it bursts. You should NEVER inflate the tires (cold) to anywhere near that. Go with the number on the sticker in the driver's door or the owner's manual.
  7. Sep 28, 2020 at 8:34 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Get those damn tires to 33~30 right now!! :eek2:
    Cpl_Punishment likes this.
  8. Sep 28, 2020 at 8:41 AM
    GiantWinston
    GiantWinston New Member
    Justin
    2016 MGM SR5 5.7l 4x4 Crewmax
    Toytec Boss Lift (3.5" front / 2.5" rear) 295/65/R20 Nitro Ridge Grapplers 2018 LED Headlight Conversion Pioneer AVH-W4400NEX Headunit
    Agree with others to stick with what's on the door sticker. I did the chalk test on my Nitto Grapplers. I found raising the pressure closer to 40psi to be a good place for even tire wear.
