Tire Pressue Suggestion
Discussion in 'Wheels & Tires' started by TRDave, Jan 21, 2018.
  1. Jan 21, 2018 at 3:31 AM
    TRDave
    TRDave [OP] New Member
    Dave
    Northern NY
    2012 MGM Rock Warrior DC
    I just purchased a 2012 Rock Warrior from a friend. It's got Duratracs in the stock size on the stock wheels, and have been run at 50psi.
    I can't really do a chalk test where I live this time of year, so I was just wondering what you guys think of running these at 50psi. Any advice or suggestions is much appreciated. Thanks!
  2. Jan 21, 2018 at 3:56 AM
    Slayer
    Slayer Member
    Slayer
    Hey Dave..
    what is the max psi rating printed on the side of tire?
    TRDave[OP] likes this.
  3. Jan 21, 2018 at 4:00 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Mine is e-rated 80 psi max and I run at 45 psi. I tried at 50 and found them to be bit harsh.
  4. Jan 21, 2018 at 4:10 AM
    Wvmoonshiner
    Wvmoonshiner 2020 T4R Venture SE
    Chuck
    West Virginia
    2020 T4R Venture Midnight black
    I ran my duratracs at 45 also
  5. Jan 21, 2018 at 5:32 AM
    TRDave
    Dave
    Northern NY
    Thanks for the replies, guys! Max pressure on these is 65psi.
  6. Jan 21, 2018 at 8:04 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    I have stock looking Michelins. Inside the door says 31 psi front 33psi rear? I run them at 35-37 psi. I would like to go higher for better gas mileage but need traction in snow and ice. Great question. Peace. D
  7. Jan 21, 2018 at 8:09 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have a different tire but same thought process. The PSI in the door is only for the OEM tires.
    I am running BF Goodrich All Terrain T/A KO2's, which are a 10 ply tire. I called BD Goodrich and they recommend running them at 55psi. I have been running them at 50. Too cold here for a chalk test at the moment, only had them for a few weeks.
    Maybe call Duratrac and see if they have any advice?
    TRDave[OP] and AxelsHumanDad like this.
  8. Jan 21, 2018 at 8:13 AM
    15whtrd
    15whtrd Mr. Blonde
    I run my Michelin‘s about the same in the front but lower pressure in the rear. That way I get the same amount of tire bulge front and rear. Typically I set my fronts at about 38 psi and the rear 28 to 30 PSI. When I first bought the truck they had it set at the PSI in the doorjamb. Very uneven tire wear. Bumping up the pressure as well as the rear sway bar helped me tremendously.
    I bump up the pressure when I tow or carry a heavy load.
  9. Jan 21, 2018 at 10:57 AM
    TRDave
    Dave
    Northern NY
    My friend bought them at our local Goodyear, and they recommended 50 psi. I haven't been to the local Goodyear in a LONG time, but based on past experiences, I can't help but wonder if that recommendation has any technical basis.
    MotoTundra[QUOTED] likes this.
  10. Feb 1, 2018 at 2:34 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Decided to follow suit . Running my Ridge Grapplers @ 45 psi on 295/70/18 's. So far rides good. I also did a speed comparison to see how much I'm off with bigger tires. To my surprise I'm only off 2+mph. :D
  11. Feb 1, 2018 at 4:43 PM
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    Cold 46 psi
