TIRE HELP
Discussion in 'Wheels & Tires' started by PlatinumDFW, Aug 11, 2022.
  1. Aug 11, 2022 at 4:26 PM
    PlatinumDFW
    PlatinumDFW [OP] New Member
    Dmitry
    DFW, TX
    22 Platinum 4x4
    Boys and Girls
    I am looking to install my 20x10 -18 wheels on the truck as soon as it comes in (take-offs off of my Silverado) currently the tires on it are 295/60 KO2 E rated.
    I am not planning on doing anything with the suspension so trying to figure out what tire to put on it so that it doesn't rub and since I'll be going smaller in size will want to put an SL or XL rated tire mainly for the weight savings.
    Here are the options:
    275/60 (33" tire) - Wildpeak SL rated - if I go with this, will I have an issue installing it on a 10" rim?
    285/55 (32.5") - Toyo AT3 SL rated
  2. Aug 11, 2022 at 5:06 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If you go to tirerack or discounttire websites and look up those tires it will tell you the recommended wheel width size range for the tire size.
  3. Aug 11, 2022 at 5:15 PM
    Does the silverado bolt pattern match the 2022 Tundra?
  4. Aug 11, 2022 at 5:17 PM
    PlatinumDFW
    Dmitry
    DFW, TX
    22 Platinum 4x4
    Yea, 6x139.7
    GODZILLA[QUOTED] likes this.
