Tire and wheel Question.
Discussion in 'Wheels & Tires' started by Dlsinger21, Mar 18, 2022.
  1. Mar 18, 2022 at 11:44 AM
    Dlsinger21
    Dlsinger21 [OP] New Member
    Donald
    2021 sport
    Hey guys I have a 20214x4 sport crewmax came with the 20 in wheels. Suspension is stock and I wanted to go with a 18x9 wheel with a -12 offset and run 285/65/18 AT tire. Will there be a issues with fit? Did some research and height is close to the same as the setup on it now. Any help would be awesome
  2. Mar 18, 2022 at 11:55 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    welcome.
    dig around the forum a bit.
    start here------>https://www.tundras.com/forums/wheels-tires.18/
    i personally think you'd have issue when turning with that much offset! you're looking at pushing the wheel 72mm away from stock which is close to 3 inches. not to mention a slightly different size. can you make it fit? SURE! :sawzall::thumbsup:
    Dlsinger21[OP] likes this.
  3. Mar 18, 2022 at 2:29 PM
    Dlsinger21
    Donald
    2021 sport
    Thank you sir I will do a little more checking for sure. I was thinking that was the same set up I had on the 2012 I had....but that's been a while ago
