Tire Air Pressure, 2023 Tundra, 37 inch tires
Discussion in '3rd Gen Tundras (2022+)' started by WhiteDevil1978, May 18, 2025 at 2:42 AM.
  1. May 18, 2025 at 2:42 AM
    WhiteDevil1978
    WhiteDevil1978 [OP] Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    ,A while back I lifted my truck six inches and replaced the factory 32 inch tires with 37 inch Nitto Ridge Grappler tires. The factory 20 inch wheels remain unchanged. Nitto recommends that I run on 29 psi all the way around now, but I build decks for a living and often tow a 12 foot enclosed trailer for tools and a 16 foot landscaping trailer to haul debris. The. 12 foot trailer setup is always around 2,500 lbs, but the 16 foot trailer is often loaded heavily and can reach around 5,000 pounds (trailer and cargo combined on both). My question is "Do I need to increase tire pressure when towing either trailer?" And if so, is there a formula to determine how many more PSI to add? Thanks in advance for any help!
  2. May 18, 2025 at 4:50 AM
    Yes. Weight carrying capacity is directly related to tire pressure. It actually takes higher pressure in Your LT tires to carry the same capacity your P or SL rated factory tires could carry. But your LT tires can handle 60-80psi, allowing them to far exceed the capacity of your p rated ones. 29 is very low for LTs, I would suspect to keep the same load capacity as the originals at the original recommended pressure your LTs would be around 36psi or so. But don’t worry, there’s a chart for that!
    Raven67 and oddhours like this.
  3. May 18, 2025 at 5:28 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    When I went from my stock 265 20's to a 285/65 20 Nitto Recon Grappler I called Nitto & asked them about this. They said run factory pressures for best wear & ride, but you can always increase for when towing & hauling but that's subjective to how much weight you have.
    WhiteDevil1978[OP] likes this.
