Tips for rear flare removal without breaking the clips
Discussion in '1st Gen Tundras (2000-2006)' started by KarmaKannon, Mar 29, 2021.
  1. Mar 29, 2021 at 4:01 AM
    KarmaKannon
    KarmaKannon [OP] Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I want to remove my rear flares and hopefully not screw up many clips in the process. I have the forked panel removal tool. I'm assuming the flare unbolts at the bottom of the wheel opening and then I use the panel removal tool to pull it straight out?
    What about a source for the spare clips I'll need to put the flare back on?
    Any sources of suggestions for the rubber edge trim stuff that will likely half fall off on the edge of the flare?
    My plan is to cut the flare back like I did to my fronts. The metal behind would also be cut. I want to use my 1.5" spacers so the rear will be a little closer to the front width. If I do that now my tire eats my flare. The picture should show what I'm trying to accomplish. Just make the rear match the cutting on the front.
  2. Mar 29, 2021 at 6:15 AM
    Professional Hand Model
    Hand Protectors
    You might have a combination of all of these. Also, iirc you can buy them in bulk aftermarket but not sure where to source them.
    KarmaKannon[OP] likes this.
  3. Mar 29, 2021 at 7:23 AM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    @KarmaKannon how did you do the front bumper like that? Almost looks like its cut in 1/2 long ways.
  4. Mar 29, 2021 at 7:26 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  5. Mar 29, 2021 at 7:35 AM
    KarmaKannon
    Utah
    Some junk
    Yep it's just cut. You also have to remove the metal bumper behind the plastic and then mount the fender sides with a bolt and spacer.
  6. Mar 29, 2021 at 7:39 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I was about to say this. @KarmaKannon probably just best to order some that PHM linked. That plastic is going to be so brittle at this point.
    Voss likes this.
  7. Mar 29, 2021 at 7:41 AM
    KarmaKannon
    Utah
    Some junk
  8. Mar 29, 2021 at 7:47 AM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    I see. I may have to try that. Looks killer and the bottom half of my front bumper has many love taps. I just got around to reading your build thread. Sweet build man. Love to see that kind of effort put in.
  9. Mar 29, 2021 at 1:53 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Can you post a link for the build page?.... Some people aren't sure how to find it in the long list of postings... @KarmaKannon
  10. Mar 29, 2021 at 3:12 PM
    KarmaKannon
    Utah
    Some junk
    Voss[QUOTED] likes this.
  11. Mar 29, 2021 at 5:15 PM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    I've removed the flares on all the first gens I've had except the current one. You're right there are bolts inside the wheel well and then it's all just tabs. Every time some tabs break and some don't. Sometimes even the plastic on the inside of the flare that holds the clip breaks too but can be fabbed to hold a clip again easy enough. And the weather stripping will separate. I've always just left them off but I wasn't cutting metal so wasn't concerned about putting back on. Doesn't answer your question but hopefully helps with what will happen when they come off. By the way, do you know Dallin?
  12. Mar 29, 2021 at 8:12 PM
    KarmaKannon
    Utah
    Some junk
    I left the weatherstripping off on the front and it seems fine but I'd rather have it on if possible. Dallin who? I've probably known someone by that name haha.
  13. Mar 29, 2021 at 8:23 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I removed mine a couple of weeks ago to replace the fender liner that goes underneath them and they all broke. It wasn’t too cold outside but they were old and brittle. I bought a universal automotive body clip assortment on Amazon and found some that fit it.
  14. Mar 29, 2021 at 8:50 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Such a killer looking truck !!!
  15. Aug 24, 2021 at 4:17 AM
    SouthPaw
    2000 Limited 4x4 AC
    What did you do to repair the tabs on the flare side? I’ve got a couple that ripped/torn that I need to repair.
