Tin clad marine vs. 100% copper
Discussion in 'Lighting' started by alb1k, Oct 9, 2021.
  1. Oct 9, 2021 at 10:03 PM
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Switch pros, 1-2 ga. users, etc. Are you using marine/tin clad or 100% copper wire? I hear marine a lot, but 100% copper has better resistance and sealed right at terminals, seems better overall. Welding cable even better.
    Also, if for instance, 2 BD Squadron Sport LEDs are 20A each, are you still hooking both of those to one switch on a switch pros 9100?
    Thank you, first post in electronics for me.
    Erik
  2. Oct 10, 2021 at 1:25 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    My Switch Pros cam with the wiring so I used that. The 4 switches left of center are rated for 20A, the 4 on the right are 35A. I have my BD squadron SAE fogs running on a 20A. Had my squadron pros I have as aux backup on 20A with no problem, only moved to 35A side to separate from front facing light switches. Hope this helps.
    Just looked at BD website Squadron Pros are 26W, but only 2A per light. I thought that something didn't seem right as far as 20A per light.
  3. Oct 10, 2021 at 2:09 PM
    alb1k
    Left Coast
    It's good
    Thank you! @AZ Red Nek
  4. Oct 10, 2021 at 2:09 PM
    alb1k
    Left Coast
    It's good
    20 for LED seemed high to me as well. Thank you for checking :)
  5. Oct 10, 2021 at 10:57 PM
    AZ Red Nek
    Chuck
    Glad I could help
    alb1k[QUOTED][OP] likes this.
  6. Oct 10, 2021 at 11:01 PM
    alb1k
    Left Coast
    It's good
    I appreciate it very much. Makes more sense that I mixed up watts and amps than LEDs would draw too much. Especially the SS.
  7. Oct 10, 2021 at 11:07 PM
    AZ Red Nek
    Chuck
    When I got my Switch Pros I thought 8 switches was overkill, I only have 2 unused now.20211010_230331.jpg
