Timing Chain
Discussion in '2.5 Gen Tundras (2014-2021)' started by Johnny650, Aug 2, 2020.
  1. Aug 2, 2020 at 10:53 AM
    Johnny650
    Johnny650 [OP] 5.7 TRD
    NC
    Silver Sky TRD
    What's up fellas? I'm wondering if anyone has any information on timing chains. Or more specifically when they should be changed. My truck is coming up on 110,000 miles. I change my oil regularly using moble1 oil and trd filters. I've never had any trouble with this truck but it has come to my attention that the timing chain should be replaced around 120,000. This is not a cheap or quick trip to the shop. But I know the alternative could prove to be catastrophic. So I guess the question is "does everyone do this at 120k ? And if not, when do you do it?
  2. Aug 2, 2020 at 11:07 AM
    P-Factor
    P-Factor New Member
    Belts need to be replaced at normal intervals (usually every 90-100k on late model cars) or you will have hell to pay. Timing chains however are a different story and will generally last the lifetime of the engine. There are no prescribed timing chain replacement intervals.
    Rex Kramer and Zebruaj like this.
  3. Aug 2, 2020 at 11:54 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    If you can hear it, it probably needs to be changed.
  4. Aug 2, 2020 at 4:20 PM
    Johnny650
    NC
    Silver Sky TRD
    Right on thanks guys. I was thinking chains would typically last the lifetime of the vehicle. But I had gone down an internet "rabbit hole" reading various comments about the subject and began to wonder about my own ride. It doesn't make any more noise than the typical 5.7 so I believe she'll be with us for at least another couple hundred K. Thanks again fellas.
    P-Factor likes this.
  5. Aug 3, 2020 at 7:50 PM
    1794 PRO
    1794 PRO New Member
    Zach
    2015 Super White 1794 Tundra CM
    Your engine will go long before you’re chain breaks. I’ve never had to replace a timing chain on any Toyota model. There’s no service interval to answer your question. Your chain can stretch but again I’ve never had to replace one. I do know other techs have though. Your chain tensioners have pretty good length of lash to compensate for any stretch. However if you hear your chain chattering/rattling I’d take it in to be looked at.
  6. Feb 21, 2021 at 7:26 AM
    Rocko9999
    Rocko9999 New Member
    Can having a bad tensioner be the exception to this? I think my driver side tensioner is going. 60-90secs of noise on very cold days, then fine.
  7. Feb 21, 2021 at 7:29 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    THIS right here ^^^. Read no further.
  8. Feb 21, 2021 at 8:27 AM
    1794 PRO
    1794 PRO New Member
    Zach
    You’re tensioners are hydraulic. They can wear and no longer retain hydraulic pressure, basically bleed off and rattle until they build pressure again. Usually 90 or so seconds after running. So yes your tensioners can definitely go bad. On a side note though, you also have hydraulic lifters under the rocker arms in you’re valve train. Same thing. They go bad, rarely but it does happen and they bleed off pressure and rattle like a mother fucker until they pressurize again. It’s important to determine if the rattle is coming from the front of the engine where the tensioner is or the top of the engine where the lifters are.
