Timing Chain Tensioner Clack of Death
Discussion in '2nd Gen Tundras (2007-2013)' started by Lifeislarge, Dec 7, 2019.
  1. Dec 7, 2019 at 5:39 PM
    Lifeislarge
    Lifeislarge [OP] New Member
    2007 Tundra 4X4 TRD 5.7L
    Can't seem to get a break. Sure, she's got 270K miles but literally everything is happening at once.
    In the last month I've replaced a solenoid in the transmission, the clock spring, front and rear brakes, installed the SAIS hack due to air pump codes, and now this. The dreaded timing chain tensioner clack has appeared out of nowhere.
    I have a shop at home, all the tools, and everything I need to do the job but man, I'm getting tired. This ain't no timing belt on a 4.7 and unless someone can clue me in on some shortcuts (which would be GREATLY appreciated) I'm looking at another big job.
    It's paid for and it has everything I need so trading it in is NOT an option and around here, the same truck would cost about $13K to replace, mind you with a few less miles.
    Just venting and looking for tips and support.
  2. Dec 7, 2019 at 5:43 PM
    TheBeast The Beach
    I know its sucks but still better than any other brands out there.
  3. Dec 7, 2019 at 5:56 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That sucks buddy I’m sorry. If it makes you feel any better I daily a 20 yr old Audi. It’s ALWAYS broken. No matter how much I fix I keep falling further behind on the repairs. I did the timing belt water pump job on it which requires removing the front end of the car. I spent 12 hours on it and then the new water pump started to leak. I just let it leak. Now the timing chain tensioners on BACK of the motor are bad.
    It has 70k miles.
  4. Dec 7, 2019 at 7:03 PM
    Blue Thunder
    Washington
    Just know if you owned a Ford, you'd be an expert at replacing timing chains by now.
    JLS in WA and Rock15t like this.
  5. Dec 8, 2019 at 10:09 AM
    Lifeislarge
    I'm literally about to lose my shit on this truck. Now the immobilizer is acting up and I have to disconnect the battery and reattach just to get it started. Any workaround for this stupid crap???
  6. Mar 18, 2020 at 8:44 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Stp oil treatment 2 quarts made my truck a lot more quite
  7. Mar 18, 2020 at 9:35 PM
    Dirt Dawg
    Dirt Dawg "It'd be a lot cooler if you did"
    Connor
    Denver, CO
    2014 Toyota Tundra Limited CrewMax 4x4
    If it makes you feel any better, Ive thrown about 5k into my land cruiser in the past year in just repair parts. Vehicles age and unfortunately certain parts need replacing.
