Timing chain noise advice gen 2
Discussion in '2nd Gen Tundras (2007-2013)' started by FrugleFriend, Jan 3, 2024.
  1. Jan 3, 2024 at 7:29 PM
    FrugleFriend
    FrugleFriend [OP] New Member
    2010 5.7 Dbl Cab TRD
    Hard cap
    He everyone,
    my 2010 5.7 has 209 000km on it. Timing chain noise from the driver side bank started to make noise approximately 5000km ago.
    no check engine lights or codes.
    Intermittently makes the noise on cold starts and low idle. Goes away if I rev the engine briefly or drive a bit.
    I’m positive it’s the timing chain tensioners.
    Just wondering if anyone has had an engine pile up because of this? And how serious it is.
    Cheers
  2. Jan 4, 2024 at 5:13 AM
    treeandsome
    treeandsome New Member
    Due an engine flush with Liqui-Moly
    FrugleFriend[OP] likes this.
  3. Jan 16, 2024 at 1:16 PM
    FrugleFriend
    Hard cap
    The engine flush worked. It’s been -30 to -37c the past few days and the truck has not made the noise after cold stars. I also used liqui moly engine oil. Thanks so much for the advice.
  4. Jan 16, 2024 at 6:23 PM
    treeandsome
    Told you that Liqui-Moly is good stuff.I be doing this from now on every second oil change.
  5. Jan 16, 2024 at 6:43 PM
    chrisf111
    chrisf111 New Member
    May have to try this. Had the tensioner noise for the last 50k miles. It's annoying, but haven't seen any issues pop up.
