Timing Belt Replacement - Proper Wire Routing - PSA
Discussion in '1st Gen Tundras (2000-2006)' started by hammeron, Jan 21, 2023.
  1. Jan 21, 2023 at 11:37 AM
    hammeron
    hammeron [OP] New Member
    2002 Tundra v8 Blue 2wd
    Proper routing of Crankshaft Position Sensor wiring, during timing belt replacement.
    BULLET POINT: The wires should end up behind the fan bracket, not in front of it.
    Yes, been mentioned, discussed many many times. Just a PSA for folks who may have
    had timing belt replaced recently by a shop, or even a DIY and did not know that there
    is a right way and a not so right way, to route the wires. I am guilty of misrouting my own.
    If your wiring is not behind the fan bracket, you need to secure it to the vertical metal cooling
    tube (I used several tie wraps), to prevent the wiring from being cut through, by the serpentine
    belt.
    I am including a few pics showing proper routing.
    I read someones comment recently, regarding this issue.....I went out to inspect the truck and sure enough, my wire
    loom had already been touched by the serpentine belt! It was then that I secured it. That comment saved me from
    becoming stranded. I hope this post helps at least one person from becoming stranded.
    w666 likes this.
  2. Jan 21, 2023 at 3:05 PM
    shifty` In South Dakota Trouble ain't hard to find
    Appreciate the PSA. If only more people would listen. If only more shops would properly secure the wire :D
    hammeron[OP] likes this.
  3. Jan 21, 2023 at 4:36 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    So much easier replacing the belt with the engine on a stand rather than in the truck...
    hammeron[OP] and FrenchToasty like this.
