Timing belt cam issues
Discussion in '1st Gen Tundras (2000-2006)' started by mattle, Aug 16, 2025.
  1. Aug 16, 2025 at 4:43 PM
    mattle
    mattle [OP] New Member
    2016 SR5 Tundra 5.7L 4wd
    None
    When replacing my timing belt i put the cam pulley marks on the ‘T’ but when i removed the old timing belt the cams ‘sprung’ cw by about 20 deg. How do i account for this when installing the new timing belt? Should i rotate the cams back ccw 20 degrees to realign the marks?
  2. Aug 16, 2025 at 5:19 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Please don’t double post.
    Redoak likes this.
  3. Aug 17, 2025 at 4:56 AM
    mattle
    None
    I dont think this is s double post if you read carefully. My first post was should I follow the Haynes manual re timing belt
    2nd post was asking for help AFTER i followed the Haynes manual with its repercussions.
    yes same topic (timing) but different questions.
  4. Aug 17, 2025 at 5:46 AM
    bfunke
    South Carolina
    Post some pics of your engine showing crank and cam positions
  5. Aug 17, 2025 at 6:12 AM
    Also, your profile says you drive a 2016 with a 5.7. Has no timing belt. Isn’t first gen. What engine are you working on???
  6. Aug 17, 2025 at 8:03 AM
    mattle
    None
    Oops sorry
    Ty for pointing that out. This is my sons Tundra that I’m working on: ‘06 V8 150k miles
    KNABORES likes this.
  7. Aug 17, 2025 at 1:18 PM
    Need to have both cams and crank at the appropriate timing marks. 20° is a small amount. If it were me, I would have the crank timed at the appropriate timing mark to correspond with the T for the cams, and rotate the cams back to the T to ensure appropriate timing. Might be easier said than done as the spring tension will fight you. Pics would help to see where your cams and crank are atm
  8. Aug 17, 2025 at 3:11 PM
