Timing Belt break - 2006 tundra 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by PadreFan, Jan 2, 2018.
  1. Jan 2, 2018 at 10:45 AM
    PadreFan
    PadreFan [OP] New Member
    jim
    2006 Black Tundra
    My 2006 tundra had the timing belt go out recently (had the 1st one changed at 125k - was pondering the second swap soon - truck has 240k mi)- torn between replacing this or letting the truck go. What is a fair repair cost on this? It is an interference engine 4.7.
  2. Jan 2, 2018 at 11:15 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    That sucks, as far as a fair price for repair, it depends on what was damaged. Camshaft lobes, piston and cylinder wall damage, bent valves, etc...
    Most likely there are bent valves and if that is the only issue then it will run you at least $2000 to $2500 for repair and parts. Honestly your money might be spent more effectively if you purchased a used 4.7l and had it installed or you could always install a 3.4l, the motor mounts should be the same.
  3. Jan 22, 2018 at 5:40 AM
    WhiskeyPapa
    WhiskeyPapa New Member
    I have 4.7 l I force engine sitting on the shop floor if you're interested
  4. Jan 23, 2018 at 8:31 AM
    PadreFan
    jim
    2006 Black Tundra
    I appreciate the both responses. I sold my truck to the shop. Even if I did fix the truck everything else still had 240,xxx miles on it. Hated to see it go - best vehicle I have ever owned.
    Filthyphil likes this.
  5. Feb 3, 2018 at 7:30 PM
    Phillipk98
    Phillipk98 05 sequoia
    2005 sr5 sequoia
    What are you asking for the motor?
  6. Feb 8, 2018 at 5:25 AM
    WhiskeyPapa
    I sold it last week.
  7. Feb 11, 2018 at 3:41 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    So the guy with the million mile Tundra didn't influence you? I bought mine with 350,000 miles on it and now have 426,000 miles and I don't loos a drop of oil between changes, and still take this truck up to it's redline......very often. If the timing belt brakes, you need to do a leakage test on the engine.......this will tell you if anything got damaged without guessing or taking the heads off.....like why, what a waste of time. Leakage test my friends, sometime no damage may occur, sometimes it can. A quick leakage test will save you all the time.
    garnaz, GNTundra, Y0TA PR0 and 2 others like this.
  8. Feb 13, 2018 at 8:10 PM
    Phillipk98
    2005 sr5 sequoia
    Dang
  9. Feb 14, 2018 at 12:16 PM
    toyotapete
    toyotapete New Member
    2004 Tundra extended cab 4x4
    7'6" snow way plow
    I know of many instances where 4.7 timing belts have broken and no internal damage has resulted. My only theory is if it happens at lower rpms you are usually ok.
    Filthyphil, garnaz and mudslinger79 like this.
  10. Feb 14, 2018 at 2:25 PM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    My friend bought the gen 1 Tundra from used car dealer at 110k (not sure if timing belt was replaced) and he had it until 240k (no timing belt replaced) then sold it to me. I replaced waterpump,thermostat, timing belt and tensioner at 245k and it now has 291k.
    mudslinger79 and 15whtrd like this.
  11. Feb 20, 2018 at 7:53 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    You're right. We recently had a 4.7 that had the tensioner go out. Threw the belt all out of wack. Wouldn't start initially. Checked, fuel and spark, both were good. Pulled the timing covers, WAY out on both sides. Easily 6/7 teeth. Pulled the tensioner, replaced it, lined everything up, started right up, like nothing. Now, if you're going 80mph down the interstate and the belt breaks, I can see damage. But low RPM, belt breaks, tensioner poops itself, you're gonna be ok.
  12. Feb 23, 2018 at 5:47 AM
    JLS
    JLS New Member
    Here's another Had the exact same issue with my 2005. First timing belt replaced at 110,000. Cost was $650 for belt, water pump and labor in 2012. But my second belt recently broke at 180,000 and was told by dealer and a number of well respected Toyota specialized shops that the 4.7 engine was "an interference engine" and was toast. Couldn't bear to give her up for scrap or to spend the $3,000+ to change engines. Took a chance and replaced the belt. Good compression, no codes, no noise and runs great!! Got my truck running for cheap money and a smile on her face and on mine too.
    Lessons learned:
    1) Listed as interference engine, but make sure you check for valve damage as it may NOT have occurred if belt broke.
    2) Use a "Toyota" timing belt --no other --- as the second belt was not OEM. NOT WORTH THE FEW BUCKS YOU SAVE
  13. Feb 25, 2018 at 5:53 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    The tensioner for the timing belt, once set is bolted on in it's set positon and should not come loose. It is not the same type tensioner as the drive belt. It's an interference engine alright, but doesn't mean you will bend valves every time a timing belt breaks. In that case you do a cylinder balance test, which is a combination of a compression check and leak down check.............I can tell with just a leak down test. Most of the timing belts I see that break are from first start up in the morning, but can happen anytime. Just replace it at it's due time. Look in de Book.
  14. Jul 1, 2018 at 8:25 PM
    Housebuilder
    Housebuilder New Member
    02 Tunrda 4x4
    Hey Zombie, I was just reading this thread from Feb and you said:
    "Most of the timing belts I see that break are from first start up in the morning, but can happen anytime."
    I'm thinking mine just did that. I've been out of town for a week and today tried to start my truck. it cranked and tried to fire one time but didn't start. Now it turns over, seems kind of fast and makes a higher pitched whining sound when turning over. Sounds like there is no compression and doesn't fire. Is this what they sound like when the timing belt breaks at start up? This is an 02 with 320,000 miles on it. Not sure when it would have had a timing belt replaced. Thanks
    Y0TA PR0 likes this.
  15. Jul 2, 2018 at 12:02 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome to the forum. Since this thread is a bit older you may want to quote zombie or tag him. So you get his attention. @zombie
    :thumbsup:
  16. Jul 2, 2018 at 1:37 AM
    ZPMAN
    Minnesota
    On my 89 V6 toy i let it sit for 2 weeks and a mouse built a nest in the timing belt that made it break.
  17. Jul 2, 2018 at 1:46 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    Hey House, my Camry timing belt went out and it sounded and acted just like what you described. My Tundra has never had a broken belt so I can't compare that vehicle.
