Time to replace ball joints… which route to go???
Discussion in '2.5 Gen Tundras (2014-2021)' started by Muleycrazy13, Jul 25, 2023.
  1. Jul 25, 2023 at 5:55 AM
    Muleycrazy13
    Muleycrazy13 [OP] New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    My 2015 tundra with 133k miles is starting to seep grease out of the lower ball joints. I’m thinking it’s time to replace them all. My question is should I replace just the ball joints themselves or buy new upper and lower control arms with the new ball joints already installed?? Any brands to stay away from? I will likely replace the tie rod ends as well. Then take it in for an alignment.
  2. Jul 25, 2023 at 6:14 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    LBJs are easy to replace with a ball joint tool. I bought the one at HF and also bought the longer clamp cuz the one that comes with the kit is too short.
  3. Jul 25, 2023 at 6:17 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Replace your LBJs if all else down there looks fine in the LCA. LCA replacements are expensive and you'll also need new CAM bolts to go with them (which many people claim should be OEM bolts or bust). Get the Beck Arnley ball joints or any 3rd party that uses 555 Senkei as the actual manufacturer. UBJs would be either Beck Arnley or AC Delco, unless you want to go aftermarket UCA. If going aftermarket, the JBA UCAs are really nice and have very easily serviceable UBJs for them.
    Muleycrazy13[OP] likes this.
  4. Jul 25, 2023 at 6:18 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Coachbuilder1 likes this.
