Time for front brakes- vendor recommendations?
Discussion in '2.5 Gen Tundras (2014-2021)' started by frichco228, Oct 13, 2020.
  1. Oct 13, 2020 at 2:26 PM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Just 40k miles on my 2016 but the front brakes shimmy (so common) so it will be time to replace pads and rotors soon.
    I have been looking at buybrakes.com. Any better vendors out there? I saw tire rack had lots of choices as well as rockauto. Rockauto does not get a lot of info on the kits, so far that was my least favorite site.
    Not really a fan of drilled rotors for a truck. Slotted is good as well as open to cryo rotors as long as they don't cost a fortune.
    For the price I am considering the Centric premium brake kit. Had also been looking at the stoptech truck and tow kit which is a bit more $ but they are sold out now. I am not going to spend $400 on front pads and rotors so am open to suggestions. I do tow a 3000lb pop up camper and you never know, may upgrade to a bigger true travel trailer in the future.
    What has worked well as far as kits/components and vendors?
    Inquiringone likes this.
  2. Oct 13, 2020 at 2:31 PM
    frichco228
    Also just checking out autoanything, the Z36 kit looks decent, but I wonder if I will feel those drilled rotors every time I hit the brakes.
    Looks like they also have the stoptech truck and tow kits in stock.
    I just want something that stops as well or better than stock and will not be needing to be replaced in 15k miles due to shimmy or warping issues.
  3. Oct 13, 2020 at 2:38 PM
    kevine0001
    kevine0001 New Member
    Kevin
  4. Oct 13, 2020 at 2:40 PM
    timsp8
    NY
    I had the Z36 for awhile. It’s a lot softer than stock and your pedal will travel farther because they are ceramic. I was driving down mt Washington and the brakes got up to 500-600f and I got brake fade. I replaced them with ebc orange when I got home and the pedal has a much better feel and good stopping distance.
    If you find what you want, check Amazon too.
  5. Oct 13, 2020 at 2:43 PM
    frichco228
    good info, and that is why I am asking. I had no idea a ceramic pad could feel different.
    RastaMan69 likes this.
  6. Oct 13, 2020 at 2:43 PM
    timsp8
    NY
    Being this close you could wait and check Black Friday sales. I got the z36 kit from Amazon last bf for $300.
    Tileguy and Inquiringone like this.
  7. Oct 13, 2020 at 2:45 PM
    timsp8
    NY
    Yeah I had them on my 10 and then my 18. Definitely a softer feel. I thought something was wrong and kept bleeding my brakes until I read that it was because they are ceramic. Others had the same experience if you search for reviews.
  8. Oct 13, 2020 at 10:30 PM
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    Oddly enough when I had them on my silverado, there was zero fade and the pedal was firm. I just ordered detroit axle drilled and slotted rotors for the front and z36 pads and the standard detroit axle rotors and pads for the rear. Got the standard kit for the rear since the front does most of the braking anyway. Rest of my parts should be hear on Friday, so they should be installed sometime Saturday or Sunday. Also, thing to note about the z36 pads, bedding the pads is extremely important, as it is with any pad without a break-in coating. Ebc works well because they put a coating on the friction material to help bed the pad to the rotor without needing to do all the steps that standard pads require.
  9. Oct 13, 2020 at 10:52 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Take some pictures if you can while being mounted and give a reply on how they work out.
    I have some setting in my Amazon basket, but I liked the slotted only disc. Ive heard another member say his got worped after a towing trailer trip. But they were a different manufacturer. If you can let’s us know how it works out for you.
  10. Oct 14, 2020 at 7:28 AM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    I’ve never owned EBC, are the rotors good as well? How does their quality of parts compare to Powerstop? I’m guessing the powerstop will last longer because they’re ceramic?
  11. Oct 14, 2020 at 7:39 AM
    timsp8
    NY
    I have been impressed with ebc. The pedal feels much better to me. I’ve only had them for about 800 miles and ebc says it’s not fully bedded until 1500 miles. I left my power stop rotors on, but next time I might go with stoptech cryo rotors. Ebc rotors are expensive.
    The only issue with ebc is they come with piston caps for the squeak. They give you 4 for the front, even though you’d need 8. I didn’t use them and bought shims from Toyota. I did use them on the back and don’t have any squeals.
  12. Oct 14, 2020 at 7:40 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I posted the same question about a month ago. No firm consensus. Some are Chinese junk, so beware. It appears, EBC has been brought up more often without any disappointments. PowerStop appears to have a 70/30 relationship, and CRYO are mentioned but seldom used. I was left with the EBC option. I'm a 2016 with 49k. I have some wobble and fade during heavy braking. Still have pad left.
    Skew12 likes this.
  13. Oct 14, 2020 at 11:59 AM
    Mr. White
    Mr. White Poco Loco
    San Antonio
    2020 Family 4x4
  14. Oct 15, 2020 at 6:15 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    https://www.buybrakes.com/
    These guys have the best support, aggressive pricing, lots of specials and fast shipping.
    Cryo rotors with ebc.
    Can’t go wrong.
    If you add your items to the cart, leave it there overnight and add your email, they’ll typically send a discount code to persuade you to complete checkout.
    deptrai, Flyinryank, Njmike13 and 5 others like this.
  15. Oct 15, 2020 at 8:05 PM
    Inquiringone
    Ter
    NorCal 408
    What’s not to like about that. :eek:
    I like discounts, and almost ready to swap out front end rotors & pads and struts.
    I’ve had stop tech on a f150, slotted rotors. They worked ok.
    I’ve heard better reviews on cryo treated rotors (black ones) & ceramic pads... Hopefully Black Friday, and discounts are plentiful will be the time line to score big. :fingerscrossed:
    Hightide[QUOTED] likes this.
  16. Oct 15, 2020 at 9:13 PM
    Hightide
    Abalama
    Magic School Bus
    I’m a, drive it like I stole it, kind of guy.
    Cryo are the only ones I haven’t warped.
  17. Oct 15, 2020 at 9:57 PM
    Hunterdan
    2017 Inferno DC SR5
    Detroit axle rotors came in today. Will be installing them this weekend. All I gotta say is, these have to be the heaviest rotors I've ever had on a vehicle. Think they are heavier than the drums on the rear of my 2010 silverado. Rotors look great, surfaces all look really good. I'll be happy to get rid of the shaky wheel here soon.
  18. Oct 16, 2020 at 2:56 AM
    Adam New Member
    I just bought some hawk yellows the other day off of Amazon 68 for the front and 39 for the rear.. Then I bought the centric cryos from Autoplicity (non slotted). I probably wont get to put them on for a couple weeks, but that is what I went with.
    Hightide likes this.
  19. Oct 16, 2020 at 6:17 AM
    frichco228
    I have not been able to find cryo rotors on their site. ?? They just do not show any when I input my truck info- 2016, sr5, etc.
    I have seen them at tirerack, but would like to purchase everything from one vendor.
  20. Oct 16, 2020 at 6:21 AM
    SouthWestGA
    SouthWestGA New Member
    I have used seller BrakeMotive brake kits off eBay for a number of years without issue. I get blank rotors and pads,nothing drilled or slotted. They are affordable as well.
  21. Oct 16, 2020 at 6:51 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I will be going with StopTech slotted cry treated rotors and EBC Yellowstuff pads in about 15-20k more miles. 61A2722A0A0.aspx.
    deptrai and Inquiringone like this.
  22. Oct 16, 2020 at 7:00 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    I will be going with Keith at DirtyDeeds for the rotors.
  23. Oct 16, 2020 at 7:23 AM
    Hightide
    Abalama
    Magic School Bus
  24. Oct 16, 2020 at 7:31 AM
    Hightide
    Abalama
    Magic School Bus
  25. Oct 16, 2020 at 7:44 AM
    Inquiringone
    Ter
    NorCal 408
    I like that^^^^
  26. Oct 16, 2020 at 9:08 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I have 49k on my 2017 and the steering wheel shakes when braking. I have been undecided in what to get. I was ready to just get OEM replacement parts because of to many options. I just looked at EBC slotted rotors with yellow pads. I have a non lifted, stock tire truck and I tow a 5k pontoon boat. Any thoughts?
  27. Oct 16, 2020 at 9:12 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
  28. Oct 16, 2020 at 9:12 AM
    timsp8
    NY
    Ebc pads are good but their rotors are expensive. Even cryo rotors are cheaper.
  29. Oct 16, 2020 at 9:13 AM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    deptrai and toyofan87 like this.
  30. Oct 16, 2020 at 9:14 AM
    frichco228
    Well, as you have experienced and if you have looked around on this site, front brakes are a weak link on 3rd gens. There are so many people that have shimmy, warping, etc. So you are in the same boat at me. I just want something that performs as well as stock but won't warp or shimmy after a few thousand miles. Oh, and does not cost 400-500 for simple rotors and pads!
