Time delay for locking doors on 2021 Limited?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueCollar89, Feb 7, 2021.
  1. Feb 7, 2021 at 7:46 AM
    BlueCollar89
    BlueCollar89 [OP] New Member
    Wes
    New Mexico
    2021 Army Green Limited TRD Off-road Crewmax
    Tint, rear Firestone airbags, 285/70r18 Nitto Ridge Grapplers
    Does anyone else have this issue? I cannot turn the truck off, get out, close the door and then lock it right away. It has the smart handles which won’t lock it right away. But it won’t lock right away on the key fob either. It worked for the first month but now it just stopped all the sudden. Not sure if I changed a setting accidentally or what. Any ideas or anyone else experiencing this?
  2. Feb 7, 2021 at 7:53 AM
    Willard
    Willard New Member
    2024 F250
    Did you change your rear cab light bulbs to LEDs?
    Saltyhero13 likes this.
  3. Feb 7, 2021 at 8:00 AM
    BlueCollar89
    Wes
    New Mexico
    Yes I did. Now that you mention it I vaguely remember hearing something about that affecting things, wasn’t it remote start though? My remote start works perfectly.
  4. Feb 7, 2021 at 8:34 AM
    Willard
    Willard New Member
    2024 F250
    It causes interference with the antenna for remote lock/unlock. You should put the original bulbs back in, or turn off the exterior cab lights via the switch.
  5. Feb 7, 2021 at 8:44 AM
    BlueCollar89
    Wes
    New Mexico
    Oh ok. Thanks for the input I will try that out and see if it’s what’s causing it!
  6. Feb 7, 2021 at 8:47 AM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    The LED bulbs from HR revolution are specifically made to not have that problem. I have them in my 2020 and no issues at all.
    aberserker and Saltyhero13 like this.
  7. Feb 7, 2021 at 8:49 AM
    I think Vleds has that issue too and are doing a redesign IIRC.
  8. Feb 7, 2021 at 9:03 AM
    BlueCollar89
    Wes
    New Mexico
    I’ll probably order some if that turns out to be the issue. Thanks.
  9. Feb 7, 2021 at 9:03 AM
    BlueCollar89
    Wes
    New Mexico
    Just to clarify, it is the cargo bed lights at the top exterior of the cab correct?
  10. Feb 7, 2021 at 9:04 AM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Correct- cargo bed and 3rd brake light
  11. Feb 10, 2021 at 3:38 PM
    BlueCollar89
    Wes
    New Mexico
    Thanks for the help guys. Just to let anyone else having this issue know, I tried to just leave the cargo light switch off when opening doors and stuff and sure enough it works like it should! I think I’ll just leave that switch off and only turn it on when I need it.
  12. Feb 20, 2023 at 10:52 AM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    You guys are geniuses. I've been having this issue and did a quick search and this was the first thing that came up. Never would have guessed this was the issue.
    Sorry to necro an old thread but wanted to give my THANKS. THANK YOU!
