Tie Rods need replaced!
Discussion in '2nd Gen Tundras (2007-2013)' started by FlatAir2, Apr 29, 2021.
  1. Apr 29, 2021 at 11:55 AM
    FlatAir2
    FlatAir2 [OP] New Member
    Shaun
    2012 Grey Tundra CrewMax Rock Warrior
    I need a to replace my inner and outer tie rods, where would you go to purchase them?
    I’m being quoted $67(outer) and $72(inner) each...good price or not?!?!?
    Dr Doobie likes this.
  2. Apr 29, 2021 at 12:03 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Stock suspension?
    *The reason I asked is, my tundra has a lift kit and stock tie-rod would not work.
    I had to replace mine with ends from the manufacturer of the lift*
  3. Apr 29, 2021 at 12:08 PM
    15whtrd
    15whtrd Mr. Blonde
  4. Apr 29, 2021 at 12:13 PM
    15whtrd
    15whtrd Mr. Blonde
  5. Apr 29, 2021 at 12:32 PM
    FlatAir2
    Shaun
    It has a 3/2 leveling kit.
    Dr Doobie[QUOTED] likes this.
  6. Apr 29, 2021 at 12:45 PM
    Dr Doobie
    Talkeetna,Alaska
    Cool,Then you should be good to go with stock ends.
  7. Apr 29, 2021 at 1:51 PM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    15whtrd likes this.
  8. Apr 30, 2021 at 8:17 AM
    Forcefed
    Forcefed New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    If you plan on doing the inner make sure you have a pipe wrench and the wrench you need. My buddy brought over a inner tie rod removal tool for his F150. The inner tie rod was bigger than the tool he had.
