Tie Rod Jam Nut Size??
Discussion in 'Suspension' started by Vam_Xyooj, Apr 2, 2025.
  1. Apr 2, 2025 at 10:08 AM
    Vam_Xyooj
    Vam_Xyooj [OP] New Member
    2008 Toyota Tundra Dbl cab Trd
    What is the size/thread or part number of the tie rod jam nut? Both my driver and passenger jam nuts are seized, and I'd like to replace them if I'm unable to remove them. I bought new outer and inner tie rods but neither came with a jam nut and I'm Having troubles sourcing the jam nut size. For context, the truck is an '08 Double cab 4x4. Any help is appreciated.
    Would a zinc plated or yellow dichromate plated nut be sufficient as a jam nut?
  2. Apr 2, 2025 at 10:35 AM
    AZBoatHauler
    So.Arizona
    I’m pretty sure 27mm - I can check.
  3. Apr 2, 2025 at 10:37 AM
    AZBoatHauler
    So.Arizona
    It’s 30mm
  4. Sep 14, 2025 at 7:12 AM
    Cn42
    Cn42 New Member
    Did you ever get this figured out? I am running into the same problem.
  5. Sep 14, 2025 at 7:50 AM
    Vizsla
    Vizsla pretend2send
    Jamb nut is M22 - 1.5
  6. Sep 14, 2025 at 5:51 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum Tundra
    2007-2022 Tundra Part# 90170-A0007
