Ticking noise from transmission
Discussion in '3rd Gen Tundras (2022+)' started by Fooyotatundra, Jan 13, 2023.
  1. Jan 13, 2023 at 3:33 PM
    Fooyotatundra
    Fooyotatundra [OP] New Member
    2022 sr5 trd 4x4
    Just made this thread so people can be on look out for the ticking noise coming from the transmission. I hear mine when pressing the brake at a full stop while in drive. First heard it going thru the drive thru, but if you do hear it on your truck most likely needs a new transmission.
    My trucks currently at the dealer waiting for them to let me know what’s going to happen next but service manager said they just replaced another tundra’s transmission that came in with the same ticking noise.
    So just aheads up!
    *not my video but it’s the same noise
  2. Jan 13, 2023 at 3:39 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Dang. Sucks to hear. Hope they fix you up quickly!
  3. Jan 13, 2023 at 5:08 PM
    ChrisCamp
    ChrisCamp New Member
    23 Crewmax
  4. Jan 13, 2023 at 5:20 PM
    Fooyotatundra
    2022 sr5 trd 4x4
  5. Jan 13, 2023 at 5:22 PM
    Fooyotatundra
    2022 sr5 trd 4x4
    Dealer hasn’t confirmed mine needs a new transmission but looks like it’s going that route
  6. Jan 13, 2023 at 5:24 PM
    TTund16
    TTund16 New Member
    Weird noise for the transmission! If it was my car, I would have thought it's harmless ticking since v8's are master tickers! :D but this is v6 ... still the same.
    what's the trans issue for those with that problem? Anyone knows?
    Kentucky Tundra likes this.
  7. Jan 13, 2023 at 5:29 PM
    ChrisCamp
    23 Crewmax
    Update with what they say. I also need to have my rear door window seals looked at, have the infamous gap they’re talking about.
  8. Jan 13, 2023 at 5:43 PM
    Fooyotatundra
    2022 sr5 trd 4x4
    Hahah I have that too but haven’t had any issues with water or anything so I’m alright for now but will update once I hear back.
  9. Jan 13, 2023 at 5:44 PM
    Fooyotatundra
    2022 sr5 trd 4x4
    Have no clue hahah I’ll see what the dealer says.
    Kap1 and TTund16[QUOTED] like this.
  10. Jan 13, 2023 at 7:33 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    After a hemi v8 I'm pretty much over trying to listen to any engine noises... And just try not worry about it as I got warranty for 10 years, and noises will get worse if it's an issue
    But thank you for posting his noise, I'll be on lookout now!
    Libagui, Whitatu19, Henry1jg and 3 others like this.
  11. Jan 13, 2023 at 7:48 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    What was the repair? I thought they were just replacing the trans with these noises.
  12. Jan 13, 2023 at 8:18 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    So does that mean whatever they repaired last time is probably not related to this noise?
    TTund16 likes this.
  13. Jan 20, 2023 at 6:54 AM
    ChrisCamp
    23 Crewmax
    No updates from anyone?
  14. Jan 20, 2023 at 7:08 AM
    Fooyotatundra
    2022 sr5 trd 4x4
    Got my truck back after dealer performed the tsb for the clunking noise upon start up. While the tsb did fix the clunk, I can still hear the ticking. Most likely need to replace the transmission but dealer said there’s no issues with the transmission so I’ll keep driving it till something happens.
    But I’m also going to let the dealer know that the ticking is still there.
  15. Jan 20, 2023 at 8:04 AM
    ChrisCamp
    23 Crewmax
    Just got mine back, they opened a case with Toyota and awaiting a response on what they should do. I’ll update since mine is making the same exact noise as yours.
  16. Jan 20, 2023 at 10:00 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    There is a TSB for the clunking noise at start up? Better go dig that one up, mine does it once in a while, what did they do to fix it?
  17. Jan 20, 2023 at 10:17 AM
    Fooyotatundra
    2022 sr5 trd 4x4
    They had to recalibrate something to a newer version. Been about a week and haven’t heard it since, drives smoother too. There’s a thread that’s stickied with all the current tsb’s out.
    https://www.tundras.com/threads/upd...technical-service-bulletin-thread-usa.117669/
    Coasty[QUOTED] likes this.
  18. Jan 20, 2023 at 11:14 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    I have an appointment to get the TSB, thanks guys!
  19. Feb 11, 2023 at 8:46 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    So I just heard this same ticking noise when going through a drive through tonight.
    Any updates on it from anyone who had it fixed by a dealer.
    Is it still ticking on yours?
    cfus89 likes this.
  20. Feb 11, 2023 at 8:52 PM
    Fooyotatundra
    2022 sr5 trd 4x4
    Yes mine is still making the ticking noise even after the tsb update regarding the clunk at start up. Haven’t told the dealer that it’s still making the tick noise after the tsb update though since it’s driving fine.
    Not too worried about it since I also have their extended warranty.
  21. Feb 11, 2023 at 8:53 PM
    Fooyotatundra
    2022 sr5 trd 4x4
    A member on here told me they had their transmission replaced, decision per Toyota corp and hasn’t had heard the tick since.
  22. Feb 12, 2023 at 1:20 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Wow... Ok.
    I'm not even sure if I even want them to replace transmission on my truck.
    It seems to drive ok besides this ticking noise which is barely noticeable when near a wall eg drive through.
    Idk if I'll have any other issues after they replace the transmission... Does it require lifting up the cab?
  23. Feb 12, 2023 at 2:47 PM
    Fooyotatundra
    2022 sr5 trd 4x4
    Yeah mines barely noticeable as well, and I’m not sure if they would need to lift the cab.
    Kap1[QUOTED] likes this.
  24. Feb 14, 2023 at 6:13 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
  25. Feb 15, 2023 at 8:01 AM
    Beardaho
    Beardaho New Member
    23 Limited TRD LR 6.5
    I've noticed the noise in drive thrus. The truck shifts and drives smooth though. Is this ticking actually indicative of a problem, or a normal characteristic?
  26. Feb 15, 2023 at 8:51 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I don't think we have definite information whether the transmission ticking is an issue or just normal operation
    There are several members posted that they noticed the ticking in their new Tundras as well.
    OP said that another member had transmission replaced supposedly due to this ticking... But I'd say we don't have full story and understanding why it was replaced and if ticking is really an issue. Someone else said that dealership said ticking is normal.
    We don't know if it's normal or not...
  27. Feb 15, 2023 at 10:08 AM
    Beardaho
    Beardaho New Member
    It's a pretty steady, regular cadence. I interpreted it as something happening on purpose, by design but what do I know. For what it's worth, mine is a 23' delivered mid January and I already have 3k miles. I definitely pay attention to subtle noises and this one came with the truck with no change since.
  28. Feb 15, 2023 at 10:18 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    It’s on a precise rhythm. My 22 pro had it, my 23 platinum has it. The 23 1794 I test drove had it.
    99.9% sure it’s normal and all of them have it
  29. Feb 15, 2023 at 1:35 PM
    Indyfife
    Indyfife New Member
    Another question for the group on transmission noises: do you hear an electronic "whirr" type of noise when you shift to/from park? I have a brand new '23. I've talked to a few other 3rd gen owners, most of whom say theirs does the same thing but am curious if you all experience that too? Similarly, sometimes I'll hear similar noises right after I turn off the truck too but that is a bit more ad hoc.
  30. Feb 15, 2023 at 1:40 PM
    raylo
    raylo not so new member
    Frederick, MD
    Could be the electronic parking brake releasing and setting.
    NATE4SURF, Tom976, spigatelli and 4 others like this.
