Thunk going into gear.
Discussion in 'Sequoia 1st Gen (2001-2007)' started by AmericanKing06, Jun 25, 2024.
  1. Jun 25, 2024 at 4:14 PM
    AmericanKing06
    AmericanKing06 [OP] New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    I’m getting a thunk going into gear. P to D, D to P, D to R, R to D. I checked all U-joints. I didn’t find any play. Grease the yoke. I don’t have any vibrations. The shafts aren’t the problem. I think either the transfer-case is going out or the rear diff.
    When I took this video I can hear the noise coming from the transfer-case
    https://youtube.com/shorts/V0aySWX318w?si=ohph4QyGqKu7Li-l
  2. Jun 25, 2024 at 4:43 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Is the truck budging here? If theres that much play at the diff, thats your problem. Put it in 4h (or are all sequoias awd?) see if the driveshafts move that much with feet on brakes.
    it could be the t case chain, but i dont think the diff should have that much slop.
    AmericanKing06[OP] likes this.
  3. Jun 25, 2024 at 4:56 PM
    AmericanKing06
    New Mexico
    It is in 4H. Sequoia’s are part time 4wd, just like the Tundras. I can move the shaft about 1/4 inch when it’s in park with both wheels on the ground. Too much back lash causing the thunk?
    I’ve seen similar issues on the 1st gen tacoma that share the same diff as the sequoia and tundra.
  4. Jun 25, 2024 at 4:57 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Does the pinion move in/out while its clunking?
  5. Jun 25, 2024 at 5:07 PM
    AmericanKing06
    New Mexico
    No, I don’t see any movement at the pinion.
    Mr.bee[QUOTED] likes this.
  6. Jun 26, 2024 at 10:55 AM
    AmericanKing06
    New Mexico
