Thump noise shortly after take off
Discussion in 'General Tundra Discussion' started by Tundrax3, Jun 12, 2018.
  1. Jun 12, 2018 at 1:56 PM
    Tundrax3
    Tundrax3 [OP] New Member
    JB
    2018 Red TRD
    I recently bought my 2018 TRD Tundra and now I hear a noise which sounds like it is coming from the rear driver side of vehicle shortly after I begin to drive. Dealer no help - but said it is not a safety concern? Any ideas
    Rica25 likes this.
  2. Jun 12, 2018 at 1:59 PM
    Tundrax3
    JB
    2018 Red TRD
    It only seems to happen within the first 30 seconds of driving and does not repeat itself, even if I put it back in park. This is my third Tundra but the first to make a noise like this.
  3. Jun 12, 2018 at 2:04 PM
    Jrfor0
    Jrfor0 New Member
    James
    It might be the ABS system check
  4. Jun 12, 2018 at 2:10 PM
    Tundrax3
    JB
    2018 Red TRD
    I've never heard it before on my previous Tundras. Does anyone else hear this noise. Wouldn't an ABS system check happen upon start up, not at different times going down the road?
  5. Jun 12, 2018 at 2:11 PM
    Its the ABS self check. There are quite a few threads on this.
  6. Jun 12, 2018 at 2:13 PM
    TheBeast The Beach
    yep. It should only happen at low speeds right after you start
    Tundyfundy likes this.
  7. Jun 12, 2018 at 2:49 PM
    Tundrax3
    JB
    2018 Red TRD
    thanks for your responses. The problem for me is I did not hear it when I test drove different trucks with various options. I noticed it for the first time after I filled my truck up the first time, roughly 500 miles on the truck. Shouldn't it have been doing it from the start? And what causes it to do a self check and what is making the noise?
  8. Jun 12, 2018 at 3:09 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    When I bought my 2017 I noticed the same thing. It'd happen the first few hundred feet or so out of my driveway.
    By brother in law (not a mechanic) said it was probably the transmission... which freaked me out a bit...
    I haven't noticed it for a while... could be one or a combination of a few things.
    1) Usually I just got in the truck and drove. Lately I've been trying to get worse MPG* so i let the truck warmup for a few minutes before I get into it.
    2) I've got 15k mi on it. Maybe it's not as pronounced as when the truck was newer?
    3) I've just gotten used to it and dont notice it any more.
    * just kidding: not "trying" to get worse gas mileage - but I have been starting the engine so the A/C can cool the truck down sooner. It probably runs for 2-5 minutes while I get the kids strapped in and/or fiddle with my phone to pick the music I want to listen to.
    I'll play with my driving habits a bit and get back to you.
  9. Jun 12, 2018 at 3:17 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Quite a few recently on this subject*
    T-Rex266[QUOTED] likes this.
  10. Jun 12, 2018 at 5:25 PM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Does it still when I don’t warm it up.. will check with warmup next time I’m in the Tundra.
  11. Jun 12, 2018 at 5:32 PM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    OMG!! I was just emailing my service advisor about the same issue and could not describe what was going on in regard to this noise. I have a 15 CM recently purchased and was freaked out it was the tranny. I’m sure the dealer will not know about this and try to charge me a butt-loads of $$ to diagnose the issue only to tell me something unrelated and costly. Thank you so much for this wonderful Tundra community!!
  12. Jun 12, 2018 at 6:30 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    i have the same thing on my 2018 tundra
  13. Jun 13, 2018 at 5:16 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    The ABS "clunk" something I honestly hadn't noticed until I came across a thread on this forum.
  14. Jun 13, 2018 at 5:49 AM
    DustinP5
    DustinP5 New Member
    Austin, TX
    2015 Magnetic Grey SR5 Crewcab
    Retrofit Headlights, Heated/Cooled leather seats, Leveled, Pro Grille, Wireless counsel charger, TRD Shif Knob
    I heard a thump from the front of the truck at around 15mph, but it only happens when I started the truck and take off. I asked the dealer, they said ABS check, no worries. But I also asked on different forums and guys chimed in saying the same thing
    Max Power likes this.
  15. Jun 27, 2018 at 7:17 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Found this in the manual:
    LS3, Norfolk757 and Stroke250 like this.
  16. Jan 28, 2019 at 8:11 PM
    kstantonnw
    kstantonnw New Member
    Kevin
    2019 Tundra TRD Sport
    I just got my 2019 TRD Sport and I hear/feel the same thing - a slight thud/clunk just after take off. Doesn't matter if the engine is warm or not. Had my foot on the brake one of the times and there was a slight vibration. My dealer told me its the ABS. I hope they're right. And my 2014 TRD Off Road did not have this.
  17. Aug 14, 2019 at 12:35 PM
    2016SR5CREWMAX
    2016SR5CREWMAX New Member
    Pao
    2016 SR5 CREW MAX GREY
    just bought my 2016 CM sr5 32K and notice the same thump noise right after driving about a block away. Good to know there isn’t any problems with my truck.
    TILLY likes this.
  18. Aug 14, 2019 at 12:41 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    If I sit idle my MPG falls like a huge rock down a mountain.
    Kgfit85 likes this.
  19. Jan 6, 2021 at 11:05 AM
    Jingusflob
    Jingusflob New Member
    JT
    Silver 2020 Xp Predator
    None yet...just beginning
    I am a new member and this is my first post. So glad I found this info! I was about to freak out when I kept hearing this exact noise on my new truck. I thought it was the transmission or a brake caliper was sticking. Thankfully there are a lot of smart folks on here that have already figured this out. Appreciate it very much.
    AggiePhil, jonclark96 and TILLY like this.
  20. Jan 12, 2021 at 9:50 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Old thread but had to chime in here. I just bought a brand new 21 SR5 CM and I noticed this the first day. Always after first start up after shifting out of park. No matter how slow or fast I drove. Many thanks for setting my mind at ease. I talked myself out of buying a F250 so I wouldnt have to deal with problems, I was like, "really toyota? I had to be the 1 out of 1000 guys with an issue out of the box?"
    jonclark96 likes this.
  21. Oct 6, 2021 at 4:33 PM
    C_Gee
    C_Gee New Member
    Chadwick
    Tundra TRD
    2” lift
    Thanks so much everybody. Me too, just purchased a 2021 TRD Tundra and this noise has been making me sick to my stomach since I brought it home. Two trips to Toyota to diagnose. First trip, no we can’t hear it. Second trip, that’s nothing to be concerned about but couldn’t tell me what it was exactly. This helps a ton, and puts my mind at ease. Thanks again, you guys rock.
    -the new guy
    AggiePhil likes this.
  22. Dec 8, 2021 at 8:15 AM
    22trdaz
    22trdaz New Member
    22 TRD sequoia here. Just picked it up and noticing this. Possible it's the same thing? Thanks.
  23. Dec 8, 2021 at 8:22 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    it happens at 6mph after everytime you start the engine. Try it. drive at 5mph or less for as long as you want and wont hear it. Soon as you hit 6mph, you will hear the clunk.
    Kgfit85 likes this.
  24. Dec 8, 2021 at 8:30 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Yes. It’s the same thing.
    22trdaz[QUOTED] likes this.
  25. Dec 8, 2021 at 8:41 AM
    22trdaz
    22trdaz New Member
    Thanks guys
  26. Dec 11, 2021 at 6:12 PM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    Would it happen at higher speeds? Or just at low speeds?
  27. Dec 11, 2021 at 6:22 PM
    Danman34
    Danman34 New Member
    Danny
    Only happens once after start up, put into drive and go over 6 mph. Only one abs check per engine cycle.
    Kgfit85[QUOTED] likes this.
