Throttle issue
Discussion in 'Performance and Tuning' started by dtrucksis, Aug 19, 2016.
  1. Aug 19, 2016 at 9:52 AM
    dtrucksis
    dtrucksis [OP] New Member
    David
    2005 Toyota Tundra Limited
    K&N cold air intake
    I have an issue, a 2005 Toyota Tundra Limited, about a year ago I noticed that it acted as if the throttle seemed to close at some throttle settings under a medium load. Creates a feeling like I would be backing off the throttle and right back on. Does not do it under high power, putting the pedal way down or on light pressure. Toyota said it was the air pump, they changed it, problem not solved, AAMCO rebuilt the transmission, problem not solved. Could it be in the Throttle Position Sensor or MAP sensor? Or ?????
    Problem solved! Fuel pump was not putting out proper pressure. Removed and replaced. Runs GREAT!!!!!
  2. Aug 19, 2016 at 11:27 AM
  3. Mar 28, 2017 at 2:49 PM
    dtrucksis
    David
    K&N cold air intake
    The problem is fixed, after a year + of aggravation and Toyota telling me there is nothing wrong, a great automotive repair shop found the fuel pump was the issue!!!!! It now runs as it did new.
    ColoradoTJ and T-Rex266 like this.
