Throttle cutout
Discussion in '2nd Gen Tundras (2007-2013)' started by WV_Warrior, Nov 8, 2022.
  1. Nov 8, 2022 at 6:29 PM
    WV_Warrior
    WV_Warrior [OP] New Member
    Cody
    West Virginia
    2021 CM TRD Sport
    Has anyone experienced their truck’s throttle response cutting out completely while driving?
    My ‘11 cut out randomly the other day while climbing a grade on a long hill at about 65 mph. The idle stayed fine, but I couldn’t get a throttle response unless I floored it. Then it would just barely increase the throttle to the truck. After about 20-30 seconds, it came back to normal and hasn’t done it since. Any ideas?
  2. Nov 8, 2022 at 8:08 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Any check engine lights? Could be going in limp mode. You don't have a pedal commander installed or anything that is supposed to alter throttle response do you?
  3. Nov 8, 2022 at 8:21 PM
    WV_Warrior
    Cody
    West Virginia
    2021 CM TRD Sport
    No check engine light. But yes, a pedal commander is installed (it wasn’t turned on at the time though, for what it’s worth).
    Also, a Bullydog is hooked up, but a tune hasn’t been installed. It’s just there so I can monitor transmission temps.
  4. Nov 8, 2022 at 8:24 PM
    NickB_01TRD
    Nick
    KY
    I'm not a 2nd gen/2.5 gen guy but I have read about someone having a pedal commander and it cutout once or twice and he removed it. It's on this forum somewhere. It's a big part of the reason I haven't put one on my Lexus. I'm sure the faulty ones are few and far between but it just doesn't seem worth it.
  5. Nov 8, 2022 at 8:25 PM
    WV_Warrior
    Cody
    West Virginia
    2021 CM TRD Sport
    Good to know. Thanks for the heads up - I might just take it out then and see if that solves it.
  6. Nov 8, 2022 at 8:27 PM
    NickB_01TRD
    Nick
    KY
    Just seems like an easy starting point. Seems like it could be dangerous if you are say taking a turn at a yield light and the throttle just cuts out on you.
