Throttle Body Spacer
Discussion in '1st Gen Tundras (2000-2006)' started by Matix363, Apr 2, 2021.
  1. Apr 2, 2021 at 2:49 AM
    Matix363
    Matix363 [OP] New Member
    Ryan
    2000 4.7 AC Tundra
    Weapon-R custom Ram air intake, Jet Performance MAF Sensor, Denso 1.25” MAF Flange, Bosch Platinum IR spark plugs, MSD Blaster coils, 220A High Output Alternator, 05-06 modified Intake Manifold w/12 hole 330cc fuel injectors, AEM 320 LPH fuel pump, Mishimoto Aluminum radiator, Flex-A-Lite Electric Fan 13 1/2", 170 degree thermostat, HPS Red Silicon radiator & heater hose kit, DirtyDeeds JBA long tube w/high flow cats & aggressive muffler full exhaust system, UniChip Performance Chip, 2004 Tundra Tranny and more to come soon: Long Travel front&back, 37”w/Methods, Fiberglass
    I have a 2000 4.7 AC Tundra. I did buy/run an Airaid Throttle Body Spacer on it. But tonight I just found this throttle body spacer for $30. It’s 1.25” not 1” so that means more air which = more power. Anyways has anyone ran this or runs it now??
    Denso Large-Bore (1.25") Mass Air Flow Sensor Flange
  2. Apr 2, 2021 at 2:59 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Save your money. Spacers don't add any benefit on a fuel injected engine.
    Toyoda Tundra likes this.
  3. Apr 2, 2021 at 3:22 AM
    Matix363
    Ryan
    2000 4.7 AC Tundra
    Well it’s a little too late for that because the Airaid spacer was the third mod I bought for my truck. I was just curious if anyone has ever ran this Denso Spacer that’s bigger and only $30 rather than $130 like the Airaid one.
  4. Apr 2, 2021 at 4:02 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I would imagine that if it had any effect at all, it would reduce low/mid-range torque.
  5. Apr 2, 2021 at 4:06 AM
    Very few of us here buy TB spacers because they are basically nothing more than a paperweight in most cases. Someone will chime in that's used one with positive results.......possibly.
  6. Apr 2, 2021 at 4:51 AM
    Richid
    Richid New Member
    Having multiple spacers will come in handy when tuning that new NOx set up.
    Oh, your not injecting fuel BEFORE the spacer - then ya, all your doing is playing with air flow. Changing your air filter will have more impact than a spacer.
    If you like the way it looks or makes you feel better, then it's great.
    Black Wolf likes this.
  7. Apr 4, 2021 at 8:46 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I have heard that these spacers can lighten the load on your wallet.
  8. Apr 4, 2021 at 9:00 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    thats a mass air flow spacer. all it does is trick the engine into running differently and can actually cause problems.
    Darkness and 2006Tundra like this.
  9. Apr 4, 2021 at 9:01 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    By that logic you should start stacking spacers or run one huge 24" one and make mad power
  10. Apr 4, 2021 at 9:02 PM
    empty_lord
    05 rollover special
    the only spacers that have dyno proof to make power are plenum spacers. of which no one makes for these trucks
  11. Apr 4, 2021 at 9:18 PM
    Kelvin
    Kelvin New Member
    The factory gaskets are pretty thick. Just stack 4 together per side.
  12. Apr 4, 2021 at 9:54 PM
    empty_lord
    05 rollover special
    on the aluminum intakes technically.. but i have the plastic ACIS intake.
  13. Apr 4, 2021 at 10:03 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Won't Work.
  14. Apr 5, 2021 at 6:34 AM
    I say go for it. But for all of our edification's, please do a dyno run before and after and report the results. We need science here! My gut says this is a total waste of money. Cause it is.
  15. Apr 5, 2021 at 7:01 AM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
  16. Apr 5, 2021 at 7:53 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Empty beat me to it. You said throttle body but that says maf sensor, different item completely. Besides it says the bore is 1.25", not the thickness of the plate. The bore in your intake is less than an inch for the maf I believe.
    I wouldn't mess with that.
