Throttle body problems
Discussion in '1st Gen Builds (2000-2006)' started by Maugomcas, Dec 20, 2022.
  1. Dec 20, 2022 at 9:31 PM
    Maugomcas
    Maugomcas [OP] New Member
    Mauricio
    Gray tundra
    Motor
    hi, im rebuilding a st generation tundra. I rolled over in my 4x4 tundra, and got totaled. i bought a 2x4 with damaged motor. took the motor out and put my wrecked 4x4 engine with transmision and installed it on the 2x4 body. along with harness computer and everything i could think of to make the 4x4 engine work on the 2x4 body. I got the engine to turn over and run but for some reason i think its stuck on protection mode or something cause it will only accelerate passed half pedal and the throtle body valve will opens like a querter of the way. i already changed tps and still the same thing. can anybody help me through this problem. ive been stuck on this problem over 2 weeks already.
  2. Dec 20, 2022 at 11:35 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    This is in the 1st gen builds section. Would probably be better off in the regular first gen section as the builds section doesn't see as much action.
    Also when you do post it over there be more specific on year and cab configuration of both trucks. More details the better.
    Tundra2 likes this.
  3. Dec 22, 2022 at 6:34 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    CEL codes?
    Definitely a throttle body issue. Could be a bad motor, or APPS, or just a bad connection.
    Do you still have the other throttle body? The one from your 4x4 is known good as long as it wasn’t damaged in the rollover. Might be worth a swap to eliminate the possibility.
    Maugomcas[OP] likes this.
  4. Dec 29, 2022 at 3:09 AM
    Maugomcas
    Mauricio
    Gray tundra
    Motor
    Yeah i do have it. But its no good, it broke in half. Besides i already swapt 3 throttle bodies and all 3 do da same. It revs past half pedal and throtle body port only opens about 1/4 of the way
  5. Dec 29, 2022 at 6:15 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I would start looking at the wiring.
    It sounds like the throttle motor isn’t functioning.
  6. Dec 29, 2022 at 2:56 PM
    Maugomcas
    Mauricio
    Gray tundra
    Motor
    Already did and in the back of the motor there is some wires that used to be a socket but its broken and have no idea ware they go, maybe thats got something to do with it.
  7. Dec 30, 2022 at 9:06 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I think you found your problem.
    Take a photo of the plug and I can go out and take a photo of the wires in the correct orientation.
    Maugomcas[QUOTED][OP] likes this.
  8. Dec 31, 2022 at 5:11 PM
    Maugomcas
    Mauricio
    Gray tundra
    Motor
    Ok thanks, sure will tomorrow first thing n da morning
  9. Dec 31, 2022 at 6:24 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    I am very confused by your picture. Is that a solid axle under there?
    I thought when you said back of motor you meant throttle motor, not the back of the engine.
  10. Dec 31, 2022 at 9:04 PM
    Maugomcas
    Mauricio
    Gray tundra
    Motor
    Im sorry yeah thats what i meant, they are behind the engine in the bottom right
  11. Jan 1, 2023 at 1:57 AM
    Maugomcas
    Mauricio
    Gray tundra
    Motor
    Do u have any kind of harness diagram that could help me out. My head s about to explode over this shit
  12. Jan 1, 2023 at 9:23 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    here’s a wiring diagram I pulled from my archives. Maybe this will help?
