Threaded heater controls. HELP PLEASE
Discussion in '1st Gen Tundras (2000-2006)' started by Nicholas.anderson, May 3, 2019.
  1. May 3, 2019 at 2:56 PM
    Nicholas.anderson
    Nicholas.anderson [OP] New Member
    Hey guys.. as you know, the 2004 tundra has terrible plastic knobs that control the A/C and Heat, etc.
    Once I broke mine, I never bought new ones. I started using a pair of pliers to adjust the temperature, pressure, and where the air is blowing (ground, defrost, etc)
    However, I ended up stripping the rod that the knobs go onto. Does anyone know the name of this part or know how to replace this piece? Thanks in advance, I appreciate your time!
  2. May 3, 2019 at 4:12 PM
    @Roman
    Roman likes this.
  3. May 4, 2019 at 12:06 AM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
  4. May 4, 2019 at 8:13 AM
    Nicholas.anderson
    Thank you so much for the links! Did you use the sealant from Walmart on your truck?
    I hate that the switches aren’t cheap but I wish I could only find the part the knob actually fits onto.
  5. May 4, 2019 at 11:15 AM
    Professional Hand Model
    Hand Protectors
    Per these knobs: I had only one knob break years back. I salvaged the cracked piece and two part epoxied it together. The metal tensioner inside was no longer salvagable so I wedged a small piece of folded up blue tape inside the square hole on one side and inserted the knob back on the post. Created the perfect back tension and bite that the knob doesn’t fall off but still slides off for entry into the panel when necessary.
    $14 is a great deal for new knobs though.
  6. May 4, 2019 at 11:38 AM
    02goes
    02goes New Member
    The 5200 is typically used on boats and because of that I know it's strong, and considered a permanent bond by 3M. If the switch stem is plastic then use a two part epoxy as earlier mentioned, or superglue as they work really good for plastic on plastic bonding.
    You say "I wish I could only find the part the knob actually fits onto."
    Unless your jury rigging, the switch stem that the plastic knob goes onto is not a replaceable part. It is a permanent part of the switch.
